Old 02-04-2015, 03:08 PM
joelwideqvist joelwideqvist is offline
Ikea display case
Just found this display case with led light at IKEA!
It's called "Synas" (which is swedish for "be seen") and costs approx 40 usd in Sweden. 24*24*24 cm.
The Following User Says Thank You to joelwideqvist For This Useful Post:
Wishmaster (02-10-2015)
Old 02-04-2015, 03:47 PM
cinqster's Avatar
cinqster cinqster is offline
Re: Ikea display case
Now that looks good! Is it glass or acrylic? Looks to be dust proof too? Is the top removable? It looks like the top has a return edge which should keep the dust out!
Haha...just found the specs in the catalog, so questions answered!
Old 02-05-2015, 12:05 AM
Valid questions though. It's all acrylic. Top lid is removable and side walls are mounted by sliding them together and then fitting them in the base. Seems totally dust free.
Old 02-05-2015, 04:20 AM
sportracer02's Avatar
Great !!
Micha
Old 02-05-2015, 05:05 AM
lovegt40's Avatar
lovegt40 lovegt40 is offline
ItaloSvensk
the swedish names Ikea gives to its stuff is incredible. With my wife we end in tears of laugh simply reading theme
Nice one! is this in glass or plastic?
Paolo - LoveGT40 Modelworks
website www.alsoldatino.com
my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber
FB: https://www.facebook.com/alsoldatino
Old 02-07-2015, 05:12 AM
Mikezibit's Avatar
Mikezibit Mikezibit is offline
AF Vendor
https://www.youtube.com/watch?v=JlmOTcUgmKM
REFERENCE PICTURES
Old 02-07-2015, 12:59 PM
PetrolVains PetrolVains is offline
Really great tip! Thanks for sharing, defiantly going to score one or two!
Thanks!
Chris.
Old 02-10-2015, 09:36 AM
Wishmaster's Avatar
Wishmaster Wishmaster is offline
***** Lurker
Indeed a great tip. Got 2 yesterday, now they are waiting for something to put in .. :P
Old 02-16-2015, 12:33 AM
brettly brettly is offline
Do these cases hold 1:18 scale?
Old 02-16-2015, 01:37 AM
It's 240 mm in square, just measure your beauties up!
sportracer02 (02-16-2015)
Old 02-16-2015, 03:00 PM
hm..well some of mine (HWE la Ferrari,599,f12) are measuring 260mm+ ..so might just purchase the one and see how it goes..definitely ok with 2 1/43 no doubt.
Old 02-16-2015, 03:15 PM
Then it will be a question about how wide they are, right :-)
Old 02-17-2015, 02:30 PM
ulap1 ulap1 is offline
I went to Ikea store today to have a closer look at this display box. I measured the internal dimensions, the display area is exactly 22x22 cm. I use Tamiya cutting mat with 1 cm grid lines, so I tried to put several 1/24 car models on it to see if they fit within 22x22 cm area. Almost all fit in nicely, actually you can put 2 side by side in case they are parallel to side walls. In case the model is longer (1/25 monster truck), it fits if placed diagonally. I also turned the box upside down and I am pretty sure you can use it this way, too. Then the light is coming from above and the you are free to use the bottom of the display box the way you like (simulate the tarmac surface, garage floor, etc)
The Following 4 Users Say Thank You to ulap1 For This Useful Post:
joelwideqvist (02-17-2015), PetrolVains (02-18-2015), Tompidom (02-18-2015)
Old 02-21-2015, 02:51 AM
After picking one up today, i tried to fit normal 1/18 scale with no luck. Looks like 2 1/43 scales is a perfect match. Would look great as a diorama..hm..might see what I can come up with
