Go Back   Automotive Forums Car Chat > Buick > Regal
Old 12-05-2014, 09:21 AM
mn_1 mn_1 is offline
Talking 99 Regal check engine light
Hi all. Check engine light just came on. Tried 2 different scan tools (both were $150 range) and both show no codes and neither could reset the light. Is there another procedure to find a code/turn the light off? 3.8 non supercharged. Thanks guys.
Old 12-05-2014, 08:22 PM
Blue Bowtie's Avatar
Registered Offender
Re: 99 Regal check engine light
The code could be for something other than the engine/emissions system. A full bi-directional scanner such as Tech II or MT-2500 should be able to read stored and pending codes for the engine, SIR, ABS, body, and transmission. It should also be able to monitor data and clear most of the memory.
Old 12-11-2014, 10:09 PM
Tech II Tech II is offline
Is it the Check Engine light or the Check Gages light?
If check gages, there will not be a code set(usual problem is a head light out)....if it is a check engine light, a codes is set, and the scan tool should be able to read even a history code, if the light is not on at the time....
