Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 11-24-2014, 09:44 PM
monteheeren's Avatar
monteheeren monteheeren is offline
2006 Avalon high beam passenger side
Just bought a 2006 Toyota Avalon. Noticed the passenger side high beam light does not work. New bulb and still not work. I have no power to the plug. Any ideas? Had the battery out and then my passenger window did not work. Found out after you replace the battery, you have to re-initialize the windows by putting them down for 5 sec and then up for 5 secs. Work great now. Was wondering if the high beam has something similar?
Old 11-25-2014, 12:19 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2006 Avalon high beam passenger side
Probably a bad connection or broken wire. Trace the wire back until you get battery voltage and repair the bad section.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-25-2014, 12:28 AM
Brian,
Thank you for your reply!
Found the problem. All the fuses were good, but previous owned had a fuse in the wrong place. I move the fuse to the proper place, and Presto!!
There are two fuses in the fuse box that run the high beams. Lesson learned! LOL!!
