Old 06-29-2003, 06:44 AM
mrchris1979 mrchris1979 is offline
D15B Non-Vtec to Vtec
I have a D15b Non Vtec that I need to replace due to high milage. I have been seeing a lot of D15b Vtec motors available for cheap so I plan to use this motor as a replacement. I just want to make sure that I got my stats right on the swap, so here it is.... I can just pull the old motor out and replace it with the Vtec version and still use the stock ECU, Harness and Tranny. To make the Vtec solenoid work, I can use an RPM activated switch which MSD makes (meaning the Vtec solenoid is running independently and only activates when the RPM switch turns it on, range of 4600-6800 ). I'm not sure if there is a difference with the distibutors, but other wise the stock harness should plug right in to the Vtec D15B engine right ? Basically, the Vtec solenoid is the only thing that is not tapped in to the ECU and harness. Sound simple enough, but If there is something not right let me know.
crx swap to a d15b 1.5L VTEC hondarx '88 - '91 Civic | CRX | Wagon | Shuttlee 3 05-27-2005 12:40 PM
Info needed on D15B three stage VTEC CBPerformance JDM Motor & Parts info/chat 0 05-09-2005 03:44 AM
non vtec / vtec? jay1985 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 07-08-2004 03:01 PM
Non-vtec/vtec engine swaps Parsalian05 Prelude 0 09-01-2003 04:02 PM
H23 Non Vtec+vtec HiRvNPreLude Prelude 5 07-02-2003 12:23 AM
