im in the process of fixin my p.o.s. 92 civic (its posessed by the demons to not work right)
but anyhow, I'm looking to get a 1992 prelude. The insurance is the downer, but I like the H22. For around 3grand I can have a pretty nice ride with a respectable engine for stock. Anyhow, what's the differances in engine with the different models for preludes? 2nd question (relating to the topic) First thing as always is to do intake/exhuast. What's the best recomendation on exhaust without going wild spending? |
Umm.
Ones Vtec - Ones not. (As far as I know)
what models though? i know theres Si preludes
Specs
H22: (Prelude S)
Type: In line-4, aluminum block Displacement: 2156cc Compression ratio: 8.8:1 Valve Train: SOHC, 4 valves per cylinder Power (SAE net): 135bhp @ 5200rpm Torque: 142lb-ft @ 4000rpm H22(Z?): (Prelude Si) Type: In line-4, aluminum block Displacement: 2259cc Compression ratio: 9.8:1 Valve Train: DOHC, 4 valves per cylinder Power (SAE net): 160bhp @ 5800rpm Torque: 156lb-ft @ 4500rpm H22A: (Prelude Vtec) Type: In line-4, aluminum block Displacement: 2157cc Compression ratio: 10.0:1 Valve Train: DOHC, 4 valves per cylinder, variable valve timing Power (SAE net): 190bhp @ 6800rpm Torque: 158lb-ft @ 5500rpm |
define exhaust.
cat-back? header and muffler? header+catback? header and custom piping? custom piping and muffler? define intake. Cold Air? Short Pipe? Long Pipe? and on that note, if you wanna know what sounds good....you're on your own. Do a search on best sounding muffler or exhaust or what have you, and every thread will tell you the same...listen, hear somethin you like, ask the driver what it is...get one. my suggestion, cold air intake, header, custom piping, greddy evo. IMO. peace!
"Why yes, this is a GS-R." |
much thx.
im probably starting off witht eh long pipe intake. (probably a cheap ass one) then find the exhuast I like. Then I'll get a AEM cold air intake with a bypass vavle (or whatever those are called that basically keep ur cold-air intake from suckin water into engine) then save a long long time, and get a turbo. heh thx, for the avice!
you can get cold air without the water issue. the filter doesnt have to go in the front grill, or in the tire well. if you have a 5th gen you can put it in the passenger side of the bumper and gut the grill cover on the side.
iceman, AEM, and a few other companies make a longpipe/CAI for that.
