Old 06-28-2003, 10:36 PM
Touge180 Touge180 is offline
4G4d Gas
what kinda gas do you guys use cause i use 87 octane should i use something different and would it hurt. If i had like a quater tank of gas left and used another kind of gas.
My car doesn't look fast and my car doesn't look furious...so when you see my taillights fade into the distance, remember this: I was into cars long before you and the rest of the trend-humping lemmings showed up and I'll be into cars long after you move on to the next pop-culture trend that you decide to shamelessly bastardize
Old 06-28-2003, 10:38 PM
Stali08's Avatar
Stali08 Stali08 is offline
Send a message via AIM to Stali08 Send a message via Yahoo to Stali08
i just use the regular and cheaper kind at the pump, may car does fine on it
PeacE
Old 06-28-2003, 10:42 PM
joeyo joeyo is offline
Send a message via ICQ to joeyo Send a message via MSN to joeyo
I put in the medium grade at the gas station. It's generally 89 or 91 octane.
Joey
Old 06-28-2003, 11:06 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
87 .... your car is optimised to run on it anyways, putting higher octane in a stock engine is a waste of money and it will actually make your car run worse instead of better.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 06-29-2003, 12:26 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
I put the cheapest crap that burns in my tank, and it works just fine.
Old 06-29-2003, 01:19 PM
91civicDXdude's Avatar
87 for stock engines and gradma grocery getters. Use higher octane gas for more performance WITH ADVANCED TIMING
sure 87 octane will work great for your stock engine, but when you want performance, you're going to have to jump up to higher octane.
for those of you who dont know, Octane is a fuel's ability to resist preignition, or detonation (knocking and pinging). When you have advanced ignition timing and/or higher compression pistons, higher octane fuel is a must. The same goes for turbo applications as well.
Old 06-29-2003, 02:03 PM
Melt's Avatar
just to clairify ... bolt ons like I/H/E do not warrnt a higher octane gas. Most tuners still consider stock engines modded with only bolt ons to be almost stock.
AF Bay Area Crew
Propane to gas conversion - Warning serge_saati Cars in General 0 11-28-2009 09:50 AM
2000 Sonoma Gas Pedal on floor but no acceleration timaugie Sonoma | S-15 0 07-29-2009 02:25 AM
gas milage freakyfire05 ZX2 2 07-06-2009 03:14 PM
Gr. Voyager 3.3 is starting to use too much gas! esoroka Caravan | Voyager 2 04-24-2009 05:07 PM
Overheating after filling with gas dupson Dakota 1 02-25-2009 05:40 PM
