Old 04-24-2009, 02:53 PM
esoroka esoroka is offline
Gr. Voyager 3.3 is starting to use too much gas!
Guys,
Need you advice. My Grand Voyager-96, 3.3 engine start use too much gas. Usually I could take ~ 250-280 miles per tank. Now I can hardly take ~150-160 mi/tank...
I changed air filter, checked the tank cap (it fit well), there is no any leak...
What else should I check?
Thanks,
Eugene
Old 04-24-2009, 04:34 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Gr. Voyager 3.3 is starting to use too much gas!
Welcome to the forum. I would connect a scanner with a real time data capability to determine where to look first. Shooting from the hip I would suspect the upstream O2 sensor first. It is a key component in determining fuel/air ratios. You haven't just started using your A/C now that spring is here have you? How old are the spark plugs?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 04-24-2009, 05:07 PM
RIP, thanks for the reply.
1. Spark plugs are 3-4 y.o. Is it time to replace it?
2. I have not yet started to use A/C. I do not think it is related to A/C...
3. There is no warning message on the main board.
4. Forgot to mention. When I start a car or press gas I can hear the more stronger noise (like B-r-r-r) as usual!
I will change the O2 sensor, of course.
Eugene
Tags
gas , overuse , voyager
