Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 08-13-2014, 07:52 AM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
Transmission slipping
In one of my '96 Roadmasters the transmission slips. Slips pretty badly between 2-3 and sometimes (i think) between 1-2. I tried changing fluid/filter to see if that would help but no luck. The fluid that came out was almost black; lots of dark material/coloring in it (clutch material?).
Do you guys agree that this baby needs a transmission rebuild? I'm planning on buying a rebuild kit with all the clutch packs and band and doing it myself (lots of helpful videos online on rebuilding 4L60e).
[EDIT] I have heard anecdotally that the throttle position sensor may also cause this problem. Is that true?
Thanks,
Alex
2008 Tahoe SSV, 2007 Tahoe SSV, 94 GMC K1500, 93 Chev K1500, 91 GMC K1500, 2000 Wrangler Sport
Old 08-16-2014, 08:48 AM
Blue Bowtie's Avatar
Registered Offender
Re: Transmission slipping
If there is excessive friction material in the pan, new clutch discs and a band are probably a good idea. What will be more important is determining whether the wear is due to normal age and mileage or something else. If the vehicle has 150K of regular use it may simply be normal wear.
It is possible that the TPS can affect line pressure, thus affecting clamping force and the resultant bite or slip of clutches. However, there is also a pressure sensor array with limits to trigger codes if pressure is out of an allowable range. Further, the TPS affects a lot more than the trans line pressure, and will also trigger a code if its voltage is out of an allowable range. It would not hurt to scan the reported TPS voltage and/or measure it at the sensor, but I wouldn't expect that to be the primary cause of slippage unless someone has been ignoring the MIL for a long time.
While scanning the TPS voltage, also look at the transmission codes.
Old 09-10-2014, 03:10 PM
Thanks for the reply, there were no SES codes relating to TPS. Looks like it's rebuild time! Any advice/helpful hints for pulling the tranny on one of these? One of the exhaust pipes has to be dropped right?
