Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-29-2014, 02:03 PM
harkauto harkauto is offline
Synthetic transmission fluid question
Is it ok to use synthetic transmission fluid in the transmission and differential of my 1999 4 cyl Camry?
Old 04-29-2014, 03:31 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Synthetic transmission fluid question
Yes. I do. I may never change the fluid again over the life of the car. Still testing.
Don't forget the power steering pump.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-29-2014, 06:05 PM
Are you saying to just change the fluid in the power steering resevoir?
Saiphon out the old and put in new?
Old 04-29-2014, 06:58 PM
Brian R.'s Avatar
Resident Chemist
No, flush it out by draining the system and cycling the rack by turning the steering wheel with the engine off (wheels in the air) and keeping the reservoir filled until clean fluid comes out.
Old 04-29-2014, 07:50 PM
Thanks for your help Brian R.!
Old 04-29-2014, 07:56 PM
[quote=Brian R.;7128323]Yes. I do. I may never change the fluid again over the life of the car. Still testing.
Brian, I'm curious to learn more about your comment above. What do you mean by "Still Testing".
Since I have had this car I have changed the transmission an differential fluid and flilter faithfully every 30, 000 miles.
Old 04-29-2014, 08:42 PM
jerryg2112 jerryg2112 is offline
I don't think that Brian is talking about the transmission fluid. He mentions the rack which is power steering.
Old 04-29-2014, 11:46 PM
Brian R.'s Avatar
Resident Chemist
In this car, the power steering system uses ATF as the fluid/lubricant.
Old 04-29-2014, 11:48 PM
Brian R.'s Avatar
Resident Chemist
[quote=harkauto;7128352]
I changed the transmission fluid and power steering fluid in my vehicles to synthetic ATF around 80k and 20k miles ago. They have not had any fluid added or replaced since then. I am monitoring the color as a measure of quality and they are still very red in color. If they get a brownish tinge, I will probably change them and conclude they have reached a time for a fluid change.
Also, I have been told by many reputable people that it is a waste of time and money to change the filter in your transmission. It only keeps chunks of clutch material from contaminating the valve body if the clutches burn out. Normal use does not plug the filter. It is really a screen and not a filter.
Old 04-30-2014, 01:18 AM
I see what you mean now by your previous posts. Sorry, I stand corrected.
Old 04-30-2014, 08:16 AM
Brian R.'s Avatar
Resident Chemist
No big deal. No one can keep track of the fluids in all vehicles.
Old 06-06-2014, 01:36 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
Not to argue, but I'd have been careful with lifelong ATF assumption.
1. Has to be real good synth. Like Amsoil.
2. ENTIRE transmission system has to be flushed. Drain is normally only about a 3rd of overall ATF volume in transmission, torque converter, cooler, and lines. Suddenly, on some trannies, you are hit by cost of 12 qrts of premium cost fluid.
3. I can vouch for synth gear oil. THAT is lasting longer than your gear box will last for sure. Same goes for rear diff oil. In differentials like Camry's, dyff is doing pretty much nothing more than changing rotation 90 degrees. That's why they opted for ATF. Simple lubricant. Quite different in AWD vehicles with viscous differential, where it's pretty much a small AT, very sensitive to hydraulic fluid specs.
Old 06-06-2014, 09:30 PM
[quote=Brian R.;7128371]
A Toyota owner friend of mine said the same thing. Instead of buying a new filter, he will remove it about every other fluid change and just wash it out with clean tranny fluid and put it back in the car. He also said it's more a strainer for the big chunks more than it is a filter and sees no sense in paying the money for a new one.
Old 06-06-2014, 11:56 PM
Brian R.'s Avatar
Resident Chemist
I don't even bother doing that. I just leave it alone. Never had any transmission problems.
Old 06-09-2014, 11:11 PM
I tend to be a little anal with this car. I'm 62 years old and want this car to make it through at least another 10 years of my life. My goal is to hit the 300,000 mile mark and then some. Money for new cars.....or even decent used cars is pretty tight right now.
