Old 06-25-2003, 10:51 PM
Fewman Fewman is offline
Send a message via AIM to Fewman
Who has installed side markers
What are some good lookin side markers? I found these http://www.showtimeautotrix.com/inc/...l?v=1&pid=1226, are they a good deal? To install them, what kind of work do I need to do?
Old 06-26-2003, 12:02 AM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
29 bucks for side markers? I got mine from ebay for like 9 bucks, and they fit perfectly.Go to ebay, seriously, itll save you lots of money
Old 06-26-2003, 12:13 AM
GTA's Avatar
GTA GTA is offline
Whee..
he meant ones like on the fender in this pic near the door. Your talking about the corner lights.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 06-26-2003, 12:43 AM
Oops, my mistake man, ask either melt or worship, they might know
Old 06-26-2003, 07:48 AM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
wow, looks like an early stage of AMI's car....
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 06-26-2003, 07:49 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...ask either melt or worship, they might know
yeah..b/c they know everything
SOLD!
Old 06-26-2003, 09:54 AM
Skeme1's Avatar
Skeme1 Skeme1 is offline
what kind of prep work is needed so that the area you end up cutting doesnt start to rust in the future?
Old 06-26-2003, 10:01 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
we do! Bow down sucka!
lol anyways you can get the generic apc ones at pepboys for around $9 - $15 I know everyone here hates apc, but their sidemarkers are decent and dont leak ... anyways then I like to install em where the piece of rubber trim goes cause if you mess up cutting the fender you can always put the trim back on and nobody will notice. Anyways, cut the hole smaller than you think you need, then make minor tweaks as you put it in ... remember you can always make the hole bigger and not smaller so its better to cut it to small.
I reccomend using a dremel tool for doing the cutting.
As for wiring em, splice into the positive and negative wires on your corner lense, off the bulb that would normally go in the orange part if you didnt have clear corners.
Good luck.
And damn ami's car used to be clean as FAWK! I didnt recognise it till ali said whose it was.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 06-26-2003, 10:03 AM
Stali08's Avatar
Stali08 Stali08 is offline
Send a message via AIM to Stali08 Send a message via Yahoo to Stali08
Well, this is one mod im def Not gonna do!
Cause im a when it comes to my cars lighting do-da's
PeacE
Old 06-26-2003, 10:27 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
i personally prefer the jdm side marker lights...but they were going for $50 on ebay
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 06-26-2003, 10:32 AM
Wow, thanks Melt and gang, very helpful
Old 06-26-2003, 10:56 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Doing side markers is easy.
Side markers were actually pretty easy to put in. What I did was make a template using copper-clad fiberglass milled with a CNC router, although cardboard would do just fine... I used the template by lining it up with the leading edge of the door, and the top edge of the rubber side molding on the fender... I put regular masking tape over the area that I planned to cut, then traced the outline of the cutout area onto the masking tape. Then, I used my dremel tool with a cutting disc to cut the hole into the fender. Make sure to cut smaller than the outline, and if the hole ends up being too small, you can always grind it out a bit (using the cutting disc also). But if you make the hole too big, you're screwed. Just keep test-fitting the side markers and making small adjustments to the hole. Once the holes are cut to the right size, remove the masking tape, grind the edges of the holes just to get rid of any sharp edges and that's it. I wired mine up to the corner lenses...
Here's a picture of the template that I used... The red arrow is the corner that I used to line it up with the rubber strip and the door edge. Anyways, using the template this way will ensure that you cut the holes in the same place on both sides of the car.
Old 06-26-2003, 01:09 PM
GTA's Avatar
GTA GTA is offline
Whee..
you are correct. i needed a pic that showed the sidemarker and thats one of the better ones i found.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
WTS-'94-'98 signal/side marker lights DDP87 Classifieds 0 05-03-2009 05:46 PM
Whats the best way to install side skirts? Sonic Eclipse Exterior and Wheels 8 04-06-2009 10:51 AM
installing side markers? PepEscobar Engineering/ Technical 39 08-20-2003 01:51 PM
who has installed their own kit..and or how much did you pay to get it done Dark Syde Racer '88 - '91 Civic | CRX | Wagon | Shuttlee 15 11-01-2002 12:48 AM
to anyone who has installed hyperwhites kyle95g20 General 6 10-31-2001 09:39 PM
