Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-25-2003, 06:19 PM
jon91898 jon91898 is offline
93 camry fuse box
ok, hello all, i'm new here and i have a rather dumb question, but where is the fuse box located in a 93 camry. My tail lights don't seem to be working properly. when i turn on my headlights, the back lights don't glow, only when the brakes are pressed do they glow. any help would be appreciated. oh and again, could someone please let me know where the fuse box is, i cant seem to find it and i dont want to mess anything up looking for it. please email me at [email protected] t hanks in advance
Old 12-15-2003, 05:08 PM
jhaddix jhaddix is offline
Re: 93 camry fuse box
look under the hood on the near right as you stand in front, staring at the engine. Small plastic box with latch at the back.
Old 12-16-2003, 06:26 AM
djfremen djfremen is offline
Send a message via AIM to djfremen
Well, If you have the V6 then look at your battery. Exactly to the right of the battery is a covered box. This is called your Juntion Block #2. The plastic box above that is your Relay box #5. Your stop lights will be a 40A amp fuse. To check if its burned simply pull it out and look through the plastic. If the metal is melted or blackened. Replace. Hope this helps.
~Fremen
Old 04-10-2004, 06:43 PM
cky86 cky86 is offline
Send a message via AIM to cky86
layout of the fusebox
sorry to bring this topic back since it is 4 months old, but can anyone maybe show me a labeled layout of the fusebox, or tell me which fuse is the one for the radio and clock? thanks
Old 04-11-2004, 02:17 AM
Bossman Bossman is offline
Cky,
All of this info should be in your owners manual......labeled layout and all. Best of luck.
Old 08-11-2004, 05:52 PM
93camrywagon 93camrywagon is offline
In my 93 Camry wagon, the fuse box is BEHIND the drivers side ashtray type door just left of and slightly below the steering wheel. To access the fuse box, you must pull outward on the door, then grasp it on both sides and squeez slightly and the lift the door off. The fusebox containing the fuses you described will be in that fuse panel and the location of the fuses is diagramed on the back side of the little door you just pulled off to access the panel
Fuse Box Passenger Compartment & Power Dist Box nomechanicSENSE Cherokee 1 12-08-2006 10:14 AM
Interior equipment fuse box on 98 Camry Soilent Green Camry/Camry Hybrid/Vista 4 01-09-2006 06:23 PM
Power lead to extra blade fuse in main fuse box bufpilot Odyssey 0 11-25-2003 10:25 AM
Radiator fan fuse has NO power under hood fuse box! Hybrid93Hatch '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-20-2003 06:25 AM
2000 Jetta fuse box? I think tail light fuse is blown... PSORC1 '97 - '03 0 10-12-2002 06:23 PM
