Old 06-22-2003, 10:39 PM
chevyfreak chevyfreak is offline
running strait pipes?
Hi all i was told cutting your pipes off right before you cat. would not create enough back pressure and bend you valves and your engine would prolly last about 4 runs down the track. If any body knows if this is true or not it would greatly help me.
Thanks-
My new Dodge
Old 06-23-2003, 01:01 AM
Zero8985's Avatar
Zero8985 Zero8985 is offline
Send a message via AIM to Zero8985
It's possible... i know that. I was just talking to someone about that topic. It seems it's not a good idea to cut the pipes on newer cars for easy horsepower. Newer engines are made to run better WITH the back pressure than without it. 80's camaros it was possible to do and get more power out of it. But a 96 or up cavalier would probably be better off WITH it's exhaust, a bigger one, or anything to create back pressure. Besides that, it would probably sound awful.
Old 06-23-2003, 02:52 PM
H&H Motorsports H&H Motorsports is offline
Send a message via AIM to H&H Motorsports
TOTALLY NOT TRUE I RACE A 2.2L CAV 1996 OM ROUND TRACK, IN TENN. IN FIRST GEAR ON 3/8 MILE FOR 15 LAPS, THAT A WHOLE LOT OF TORTURE AND THIS CAR IS COMPLETELY STOCK. I CUT MY PIPES OFF2.5 FEET BEHIND THE OIL PAN (GOING TOWARD THE REAR OF THE CAR) AND MY CAR HAS RUN 32 RACES WITHOUT ANY ENGINE FAILURES AT ALL, SPRAY PAINT YOUR EXHUAST STARING AT THE COVERTER AND SPRAY TOWARD THE MOTOR (DO NOT USE PRIMER SPRAY) AND RUN THE CAR A WHILE, THE PAINT WILL BURN OFF BACK TO A CERTAIN POINT WERE THE PAINT STOPS BURNING CUT THE EXHAUST OFF. IT ADDS 8-15 HORSE (DYNO PROVEN).
Hracein
H&H Motorsports
Only runs with key in the START position AMAMEK9 Eclipse Problem Diagnosis 6 03-12-2011 08:47 PM
How to change gasket on cross pipe at rear of engine cmar2112 Trooper | SLX | Bighorn | Wizard 1 04-22-2010 12:50 AM
98 Cav Rad Inlet Pipe MrCheapGuy Cavalier Problem Diagnosis 2 04-20-2010 08:50 PM
99 DX header + test pipe sentoyang '96-'00 Civic 1 10-26-2009 03:34 PM
running straight pipes tencent Let's get Technical! 33 12-15-2004 09:25 PM
