Old 06-22-2003, 07:31 AM
Rufes1's Avatar
Rufes1 Rufes1 is offline
Send a message via ICQ to Rufes1
Body painting
How do you achieve the same shine and gloss as they do in the shop?
My car is white and I want to fix some panels...
If you use a spray gun with air compressor can you achieve this gloss?
Because I have heard they "bake" the panels after painting or something similar that achieve the shine.
Any input that people have had with experience is welcome.
Thanks
Old 06-22-2003, 09:44 AM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
after the paint dries you need to wet sand it with 2000, then buff it out with a wheel and a fine cut compound.
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 06-22-2003, 11:31 AM
Rufes1's Avatar
wheel and a fine cut compound.?
I know "cut and polish" just used for polishing cars//
Also if you use a spray gun do you apply a primer, gloss white then clear top coat?
Or no clear top coat?
Thanks
Old 06-22-2003, 11:38 AM
95civicman 95civicman is offline
no if you are goin to primer it first you have to spray filler primer, wetsand that down with like 400 grit, then spray sealer primer, then wetsand that down w/ 600 grit, then paint your base coat, then clear coat and use 1500 grit to wetsand it down, then 2000 grit to smooth it, then buff it out and you will have a really really good mirror like finish, that way it best for darker color cars, but since your car is white you could prolly skip the 2000 grit step and just buff out the 1500 grit becuase you won't be able to see it.
zc powered 89 CRX SI with some more stuff.
Old 06-25-2003, 05:26 AM
Rufes1's Avatar
And how many coats of the base coat and top clear coat?
thanks a bunch
Old 06-25-2003, 08:39 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
whats gonna suck is when you fix that one part, its gonna look so much better than the rest of the paint.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-25-2003, 11:20 AM
how ever many coats of clear is up to you, and depending on how old the other paint is, what you do is clear the whole side of the car that you are working on, like if you are doin the right back fender go ahead and wetsand and clear the whole right side of the car, then wetsand the whole right side and buff out the whole right side, hopefully that will blend it in better, that what i do.
Switching To WaterBorne Automotive Paint LearnAutoBody Auto Collision Network 0 04-13-2010 08:10 AM
fully body paint job price htype_r Integra 10 11-16-2003 10:58 AM
Tech Tip- Body paint stand rhmatt Car Modeling 8 06-09-2003 09:08 AM
body paint/airbrush/ airbrush paint questions simdel1 Car Modeling 15 04-29-2003 12:42 AM
how to strip body paint kelvinblade Car Modeling 8 02-03-2003 02:32 PM
