Old 04-28-2003, 03:05 PM
simdel1's Avatar
simdel1 simdel1 is offline
body paint/airbrush/ airbrush paint questions
before anyone points me to the faq, i have already looked, but it does not answere my question fully.
im am a complete health freek. i am trying for my a-levels at the moment trying to get to university, the last thing i need is brain damage from aerosols. now, i am aware of the respirators, but i just want to be absolutely sure. so iv decided to get an airbrush. so can someone tell me;
can i paint the body with an airbrush?
what paint do i use? (obviously acrylic would be the healther choise, but i have my boubts it will work)
can i spray laquer with the airbrush, or is an aerosol the only way to go?
is there a primer, or laquer that i can buy for the airbrush?
and if you can give me any other tips of anykind that would be great.
oh, and to save money i might be using the spare tire method for the air supply. has anyone else tried this? how were the results?
thanx:flash:
Simon
Old 04-28-2003, 03:49 PM
kaoru-tochiro's Avatar
kaoru-tochiro kaoru-tochiro is offline
Banned
well if you're gonna spray do it outside and you should be fine. Usually you can spray anything through an airbrush but it just has to be thinned out. The tire idea will give enough pressure to work, but barely. One time I was spraying one of my RC car bodyes and I told my friend to pump the bycicle pump because I had my air brush hooked on to it, he felt stupid but it worked.:smoker:
Old 04-28-2003, 04:01 PM
daggerlee's Avatar
As far as health oriented goes:
1.) Buy a double cartridge respirator, these cost $15-25 depending on where you go. Make sure the respirator says it's made for paint use, or that it can filter organic solvents.
2.) Buy some protective eyewear, goggles or safety glasses, to protect your eyes.
3.) If you spray indoors, buy a spray booth that has a good CFM rating. I'd say at least 200 CFM should do it for airbrush use.
4.) Don't get any lacquer thinner or paints on your hands, if you do wash it off immediately. Wear medical gloves if you have to.
If you follow the above steps you can use lacquer paints without any trouble to your health.
Dan
Old 04-28-2003, 04:09 PM
Banned
Woah!! I was waaaayy off on that one!
Old 04-28-2003, 04:18 PM
simdel1's Avatar
thanx or the advise...i could do it out side, but the neigbours are very close. they might not appreciate the paint fumes too much either
so do i need all that stuff if im airbrushing with acrylic, for the interior for example...
and is there a lacquer that can go over acrylic? or am i hoping for too much
sorry im asking so many questions...iv never painted a car before
Simon
Old 04-28-2003, 04:24 PM
daggerlee's Avatar
First off, check the FAQ. It should provide a LOT of answers to your questions. See, the model acrylic paints aren't as dangerous to your health as lacquer paints, since they use rubbing alcohol and other less dangerous solvents. But the effects of paint particles on one's health is not well documented at all. So it's best to play it safe.
Dan
Old 04-28-2003, 04:33 PM
simdel1's Avatar
iv looked, it dosent...it was more of a paint compatability problem. which the faq didnt answer
thanx for your help :flash:
Simon
Old 04-28-2003, 04:35 PM
daggerlee's Avatar
I actually wrote a small treatise on paint which you should find in the FAQ. Basically it works as "LEA" as in acrylics over enamels over lacquers, but not the other way around. Hope this answers your question.
Dan
Old 04-28-2003, 04:36 PM
simdel1's Avatar
oh, ok....
ill have another look
edit: found it, thanx....ill read through it and ask anything that isnt explained, but im sure it will be
edit 2: you lied when you said it was small!!!. i think that has explained everything. i think i will try acrylic (for the neigbours sake) but ill put a coat of clarcoat over it to polish...thanx again
Simon
Old 04-28-2003, 05:56 PM
God|Zilla168's Avatar
God|Zilla168 God|Zilla168 is offline
actually if you use airbrush the paints for these airbrush do not smell at all. No need to worry about the fume unless you are using can propellant. otherwise you only have to worry about the fine paint particles coming from the brush. Arcrylic works fine on the models you can use any paint you want as long as you thin it and after each color clean the brush before using the next color. A gravity feed is nice if you doing a lot of paint changes. Bottle feed is nice for large areas. I have both then you will go into the needle size on fine or not fine details also dual action or single action so many choices.
Current project:
Mclaren MP 4/18
Old 04-28-2003, 07:26 PM
christofurr's Avatar
christofurr christofurr is offline
I also have a question, and I'll post it in here seeing as this thread is already up and running.
Instead of using the little hobby compressors, would it be ok to use the larger, noiser light industrial compressors? Would the pressure be too great? Noise levels wouldn't be a problem for me, and these larger compressors here are alot cheaper than the mini hobby compressors (for some reason ). I'm thinking of buying an airbrush this afternoon, and until I get a compressor, I might try the tyre method too.
Old 04-28-2003, 10:02 PM
bobski bobski is offline
Those bigger compressors work just fine. Make sure you have a regulator for adjustment of pressure. A moisture filter is good to have too.
Old 04-28-2003, 10:13 PM
Mainomega Mainomega is offline
Hmm, Have you heard those bigger compressors ? Even if i were alone that noise would drive me insane. Also make sure they aren't gas powered or else
Go to walmart and buy a $79 air compressor. It comes iwth a 2 gallon tank, regulator, and a hose.
I have a Badger Crescendo, Double action. I seriously never use the air regulator on it. Save money and just get a single action with constant air.
Got Something Good ? E-mail me
Old 04-28-2003, 10:37 PM
freelunch's Avatar
freelunch freelunch is offline
Yeah for cars, single action is adequate. But since I like to use more advanced techniques with airbrushes than spraying wide strokes, I bought a double action Badger 155 Anthem.
Old 04-28-2003, 10:39 PM
chipanggo's Avatar
chipanggo chipanggo is offline
I agree, industrial compressors are too noisy. I actually have one in the garage but I use an air tank made out of an old a/c freon tank for my airbrush. I use the compressor to load up my tank and then use the tank with the airbrush for quiet operation in the house.
Regarding health issues, I use DuPont automotive paints to paint my bodies. To be sure I use a dual-cartridge respirator and use surgical gloves on my hands. I have tried many paints to use in the scale car bodies but I have to say that automotive paints are absolutely the best! But be very careful, these paints can be very toxic if the proper measures are not enforced. Make sure you use a respirator and have plenty of ventilation.
