Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-20-2003, 01:56 AM
90LShatch 90LShatch is offline
what would you do ???
i have a 95 integra gsr stock now my question is that i want to go turbo but don't know what to change or to buy so how would you guys build a 12 or 13 second integra turbo like what to buy first and what parts would you choose. also i was thinking a greddy turbo kit but they don't make them for 95 so i don't know whats a good reliable turbo thanks
Old 06-20-2003, 02:03 AM
also i forgot to mention is that i want atleast to have 290 or more horse power i would love to have 300 and to acheive this what would need changed and built i know piston w/ lower compression but what else
Old 06-22-2003, 06:22 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
people will rave to you to buy a nice t3 turbo and everything and put it together yourself. but there is a lot to it, and a lot of money to go into your car to get it to 300 Hp, and have decent tuning. First off you need a Turbo Exhaust Manifold, a cold air intake or some filter aparatus. to fit the turbo. next you will need to run oil lines from the oil pump to your turbo, then possibly an intercooler if you are running high boost. you will also need a turbo timer, BOV (blow off valve), and a whole slew of other things, Turbos are not cheap, and if you have no experience with turbos I suggest you get a pro to do it, or someone who has installed them before. you will need low compression pistons, and probably need to get the crankshaft balanced, and shot peened. might want to get your valves, and valve springs done as well. the rods will definitly need to be replaced with stronger ones. if you really want to get this done it's going to cost you anywhere from $7,000-10,000 or more depending on what you want, and what tuning you do to the motor. there are a lot of goodies you can add to this as well, but your power gains will be worth it. good luck, and if anyone has anything else to add that I missed, or overlooked, go for it.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 06-23-2003, 08:43 PM
slate slate is offline
Send a message via AIM to slate
I agree, more horse power means more money. If your planning on building a 300hp car, chances are you won't have $10,000 to dump into right away. Personally, I would go with one of the better known kits like Drag or RevHard. That way you get (almost) everything you need for turbocharging your car. A kit is good starting point to build up a high HP car. I suggest doing your homework and installing the kit yourself, but make sure you have somebody standing by for questions. Its the best way to learn. From there you could start adding on and rebuilding as you get the money. Just make sure when you start adding on, you plan ahead. Don't buy parts you won't need later. But thats just my oppinion.
NO! I DIDN'T BUY THIS CAR AFTER SEEING THAT DAMN MOVIE!
If You Had $3000 To Spend On Your GTI What Would You Buy????? VentoGLX32 GTI 17 08-13-2009 07:11 AM
What would you do with my truck? Any opinions would be awesome. LT1 Kayker C/K 6 01-18-2005 10:37 PM
If you weren't into cars, what would you be into? LX98Civic COMPLETELY off-topic 10 01-29-2002 06:51 PM
What Would You Do If You Only Had Six Weeks To Live ?? primera man COMPLETELY off-topic 30 11-01-2001 10:32 PM
