Old 06-19-2003, 03:46 PM
88CRX's Avatar
88CRX 88CRX is offline
My cat got cut up.....
anyways got the cat cut out today and i think it was a well invested mod...... its only slightly louder..... doesnt stink....... and there is more umpf to the engine (the old one was toast)
the only bad think is the slight ricer rattle but its not that bad...
zc powa
short ram intake
dc sports header
2.25 Magnaflow exhaust
h/r race springs
Old 06-19-2003, 04:01 PM
91civicDXdude's Avatar
i hardly ever belive the old "the cat was clogged up" line, becuase my car has the stock cat on it, and i was running my d15b2 for a couple thousand miles with it smoking like it was on fire, burning oil, no telling how long the previous owner drove it like that.... I drove the piss out of it when i had my d16z6, and just the other day when i went to swap the engine out, i looked inside the engine side of the cat, it looked brand new. It should probably free upa couple horses, since its a restriction, but i think a high - flow catayltic converter would be a better bet.
Old 06-19-2003, 04:05 PM
88CRX's Avatar
um my head gasket blew up and there was enough white smoke pillowing out the back to cause a small fog
zc powa
short ram intake
dc sports header
h/r race springs
Old 06-19-2003, 05:33 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
I was gonna put a test pipe on mine when my stock cat clogged cause the distributor failed, but my dad wasnt havin it so I shelled out $200 installed for a high flow (which was cheaper than another oem one)
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
my pcm wiring harness got cut and corroded. Xalis Cavalier Problem Diagnosis 4 02-23-2008 01:09 PM
Cat got shut up in blazer & messed up interior abbeyt Blazer 9 06-01-2006 10:05 PM
The cut-out remote cut-up kits...where? -cy- Camaro Discussions 13 07-22-2005 06:12 PM
cats need cutting? jeverett C/K 3 05-03-2004 11:53 PM
Cat got your tongue? Spunkymonkey Asia/Pacific 36 05-14-2002 08:02 AM
