Old 06-19-2003, 01:49 PM
sooboss's Avatar
sooboss sooboss is offline
Integra ECU for b18a vtec?????
ECU for at 93 Integra B18A With Vtec. Swap I am working on. Which makes my Integra a OB2 Right? What ECU Will work for this swap set up... which is my main question.. Will at 93 GSR ECU work for this..? Correct me if I am wrong. Also where can i get this ECU???
Old 06-19-2003, 07:12 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Are you doin Ls v-tec set up? If the head is from a 96 and up then yeh its an obd2 but from 92-95 is obd1. You can use the gsr ecu.
Old 06-21-2003, 10:00 AM
sooboss's Avatar
lsvtec yeah.thats what iam doing.. the head is coming off a jdm b16a
Old 06-21-2003, 07:34 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
If it is coming off a B16, you can use a P30, but the fuel map is going to be a little wack, since it is a 1.8. Just get a P28 chipped to run a 1.8 vtec.
b18a vtec conversion? acurac27a Integra 10 08-17-2006 09:59 PM
vtec ecu or non vtec ecu CIVICLX93 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 09-29-2005 09:39 PM
ECU for VTEC 96CivicEX06 '96-'00 Civic 6 07-19-2005 05:04 PM
ecu for sohc zc vtec bulldawg151 Let's get Technical! 5 03-03-2004 07:21 PM
