Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-19-2003, 03:03 AM
Invisiguard Invisiguard is offline
SR20 and CA18 weights??
Hey all, searched but no luck.
This may be kind of an oddball question, but does anyone know what an sr20det and ca18det long block and tranny weigh? one of these two swaps will be going into my 73 triumph spitfire, I had planned on using a CA18 since its smaller and cheaper, but if the sr20 is no heavier I would go with it. thanks for any help!
Old 06-19-2003, 08:45 AM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
that ca is at least 100 lbs less.
438whp / 373tq - 11.9 @ 126
Old 06-19-2003, 09:35 AM
VQuick VQuick is offline
I don't know about the CA, but the SR w/ tranny should weigh in at around 490lbs. I remember Sport Compact Car gave that weight, and said that their KA without a tranny weighed 493lbs.
I suspect that the CA will weigh a little more than the SR, since it is iron block and the SR is aluminum.
“What does ‘kouki’ mean? Are you saying my car is crazy or something?”
Scott-Revs: Motown Muscle
Old 06-19-2003, 11:18 AM
hmm, conflicting reports. This is what stumped me since the CA is physicaly smaller, but has the iron block. Some people say it still is a bit less than the SR some say more some say right about even
Also I was looking around after i posted this last night and it seems that the guys on se-r.net had at least a good number for the SR non-turbo. A guy had one shipped ant it was 267 pounds, also 2 seperate reports of shipped trannies weighing just under 100 pounds. And Grass Roots Motorsports lists the the SR20det engine/trans weighing 390 pounds, if we figure 100 for the trans and an extra 23 pounds for the turbo/manifold this jives with the weight for the non-turbos. I read about that article where the SR20det weighed 3 pounds less with trans than the KA long block, but they must have meant 393 not 493. If the KA really did weigh 493 with just 4 cylinders and aluminum head, it would make it 33 pounds HEAVIER than an all iron Ford 5.0 V8(460 pounds)
After finding all this info last night I couldnt find a thing on the CA! Has anyone here ever shipped one? Thanks again guys, I hope this is useful for everyone
Old 06-19-2003, 01:03 PM
yada yada yada
ca18det installed in silvia: 2469 lbs.
http://www.google.com/search?hl=en&i...ca18det+weight
GOOGLE peeps...
Old 06-19-2003, 02:41 PM
Thanks nismo,
acctually Im looking for just the weight of the engine/trans not the car, im not puting this into a silvia and am just trying to compare the weight of the SR and CA motors
Old 06-19-2003, 09:49 PM
Fliquer Fliquer is offline
Send a message via AIM to Fliquer
So which of those links in your search tell of the weight of the ca18 silvia? Not to call you out or anything, but an aluminum block is always going to weigh less than a similarly designed iron block.
Isitcontagious.com
'92 S13 coupe
KYB adjustable struts + Whiteline springs
Urethane bushings in all control arms and subframe
Cone Filter
Next up: LSD
RIP #05
Old 06-19-2003, 10:40 PM
Suislide's Avatar
Suislide Suislide is offline
CA is a good bit smaller, though, but i think you're right. it's not smaller-enough to make up for the iron vs. aluminum debacle.
-Brian
2013 Subaru BRZ Sport-Tech 6MT. Not stock.
Old 06-19-2003, 11:11 PM
yeah I tried every combination on google of
ca18det
ca18
weight
weigh
weighs
but all I came up with were those same links for car weights. As for aluminum vs. iron blocks in general, going to an aluminum block typicaly saves 30% weight, this is the usual case for chevy and ford V8s. You would think the weight savings would be more but keep in mind that they have to use a larger mass of aluminum than they did iron to make up for the loss of rigidity. So all things being equal, depending on how much smaller the ca18 is dimensionaly to the SR the weights may still be about even. I'll post too if I find out first, good stuff to know
Dual batteries and optima weight stuff. ChuckH Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 29 05-25-2004 12:06 PM
A NHTSA Study on Safety and Vehicle Weight and Size Bruce Levinson Cars in General 0 11-12-2003 03:22 PM
wheel AND tire weights j.fuggi Tires and Wheels 0 03-18-2002 03:11 PM
SR20 and Oil leaks Moppie Engine 5 12-16-2001 12:52 AM
sr20 and roller rockers Lee Engine 7 05-04-2001 12:55 PM
