Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 02-16-2005, 03:00 PM
NJH_Habitatpro NJH_Habitatpro is offline
Send a message via AIM to NJH_Habitatpro Send a message via Yahoo to NJH_Habitatpro
High Idle 2,000 rpms to 4,000 rpms any help please
My car will idle at like 2,000 if im lucky but usually 3-4,000 rpms when i put the clutch in. It willl usually do it if i hit the gas real hard and start to speed up real fast. Then it will almost do it for sure. But other times it wont and will sit on 1,000 right on the nose and sit there. I have replaced the IAC and that did not fix it, i have also changed the tps that did not fix either. ANy help would be great thanks.
Old 02-17-2005, 09:54 AM
autoenthus3 autoenthus3 is offline
Send a message via AIM to autoenthus3
Re: High Idle 2,000 rpms to 4,000 rpms any help please
check timing
Old 02-18-2005, 12:05 AM
Yeah found out that it was only the EGR it was a little loose and caused the vaccum leak. Thanks for the help though.
