Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-17-2003, 10:21 PM
94blklighting 94blklighting is offline
new clutch
i just put in my new clutch and now my car idles about 700 rpms when just sitting there. if anyone has any ideas what this is please tell me. I f this is normal plz tell me.
Old 06-18-2003, 12:07 AM
92teggsr 92teggsr is offline
That's right around where your car is supposed to idle. What was it idling at before ?
99 Honda Civic Si
Stage 2 Clutch
SPP Exhaust
Short Shifter
Eibach Suspension
17's
91 Honda Accord LX
Old 06-19-2003, 02:09 AM
about 900
Old 06-19-2003, 10:20 AM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
yeah 700-900 is about right
Darrell
thegrumpysergeant.net
Old 06-19-2003, 05:30 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
factory setting is at 850 +/- 150 rpm, so ur right where u should be.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 06-20-2003, 01:28 PM
i was wrong my car idles about 700 to 900 when i start it and when i fill her up. but then i will drop down to 300 and some times 200 usally hovers around 500 from there when just sitting at the light. i dont know what it is . I put premium because that is what supposed to be in there. i put fuel cleaner octane boost . i think i might have dirty filter or my worse fear something bigger. If you guys have any ideas to what this might be please help me out. Runs fine just when you start rough because the low rpm.
Old 06-20-2003, 01:30 PM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
Soppose your idle is to low or high, how do you change it?
Old 06-20-2003, 01:37 PM
PWMAN's Avatar
PWMAN PWMAN is offline
Your engine won't run at 200 RPM, I suggest your tach is screwed up.
Old 06-22-2003, 09:53 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
same prob....
I'm having a very similar problem with my '93 integra gs-r. when i start it up it idles normal usually, when i come to a stop light it gets very eratic, dropping down very low 300-500 rpm's and sometimes stalling. it doesn't stay low though it just drops and bounces back and forth between the low rpm and the normal one. and sometimes it will idle too high like2000 rpm but usually its the drops. i was thinking that maybe i have a vacuum leak somewhere, I have heard a faint whistleing sound occasionally, i'm not sure what it is though and i could use some help figuring it out
Old 06-23-2003, 06:14 AM
PWMAN's Avatar
I had that problem in my Daytona, it was the connection to the coil. But my connection is a lot different than on a 93 teg. Just givving ideas, i think it's in the ignition somewhere.
Old 06-23-2003, 10:01 AM
i do belive it is in the iginition somewhere.
I am going to do a tune up soon because i dont know when the last time it had one. I hope this fixes it.
Old 06-23-2003, 08:07 PM
PWMAN's Avatar
Make sure you replace the coil, that was the source of my problem.
88' Dodge Shadow- 2.2L, 5 speed...a couple mods
[email protected] MPH
Old 06-24-2003, 11:55 AM
knorwj's Avatar
more....
well as for ignition i have mostly a brand new ignition system, coil, plugs wires, etc.
Not sure this i the whole problem but my water pump went yesterday, my car leaks like crazy now an i can't drive it for fear of warping the head.... I'm not sure but i believe the timing belt is what drives the water pump so if the pump was getting bad could it have been throwing off my timing? could this have been the problem all along?
New clutch new quadrent still wont disengauge NJH_Habitatpro Mustang Problem Diagnosis 11 10-09-2006 12:34 AM
2002 Jetta For Sale - 2 liter, New Bearings, New Clutch MouthNCo '97 - '03 0 01-24-2006 10:13 PM
had a new clutch installed and now the clutch has no tension? igota20hpweedeater 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 07-23-2004 04:32 PM
94 Swift & NEW Rebuild Kit & NEW Clutch Kit + MORE - CHEAP godsynet Swift 2 06-17-2004 10:45 PM
HELP! Got new clutch installed and SMELLS! also a clutch technique ive never heard! QSDA Engineering/ Technical 8 12-21-2003 11:45 PM
