Old 06-17-2003, 08:53 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
ls swap header problems
ok i got my oil pan on, and im trying to get my header on. but the lower part of my header hits the oil pan right where the pipes bend, how did u b series swap guys handle this ?
or more of, what kind of header do u think it is because i know a ls header would fit, would a b16 header botl onto the block and clear the oil pan ?
Team Lonely Drivers
Old 06-17-2003, 09:43 PM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
Headers are almost always a problem to get on, how much does the header need to move in order to clear the oil pan? Is it a close fit, or does the header not even come close to clearing it?
Beer tastes better upside down.
Old 06-17-2003, 09:57 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Any B series header will fit a B series motor.
Is the header all put together, or are you trying to get the bottom half to mate with the top half?
Old 06-17-2003, 10:05 PM
im trying to mate the bottom half with the top half. i only need like maybe an inch, its really close
Team Lonely Drivers
Old 06-17-2003, 10:52 PM
I usually have to wrestle with headers when we put them on, sometimes I have to heat things up with a torch in order to get them to fit. But an inch is quite a bit, and I seriously doubt that heating the header will make that much difference.
Old 06-17-2003, 10:56 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
What kind of header is it? If its a Neuspeed one then I wonder if you got mine I ordered one from them and they sent me a 94-01 LS header.
Old 06-17-2003, 11:46 PM
actually its less than an inch but i cant be sure exactly. why the 94-00 ls header wont fit on yoru ls motor 91civichatch, or u dont even have a b series motor ?
Team Lonely Drivers
Old 06-17-2003, 11:50 PM
no, i ordered a header for my ZC and got that sent to me for some reason. Oh well
Old 06-17-2003, 11:52 PM
did it fit ? do u still have it ? if it will bolt onto my ls and fit right, i might be willing to buy it from u, how much ?
Team Lonely Drivers
Old 06-18-2003, 12:01 AM
Sorry, I just sold it on ebay for $230. It was in the classifieds section here for a week or two for I think $150 but got no bites so I resorted to ebay.
Old 06-18-2003, 12:17 AM
that sucks.
does anyone know if a 94-01 header will fit on my ls and fit right no problem, even bolt up to my exhaust ?
Team Lonely Drivers
Old 06-18-2003, 12:46 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
are you trying to attach the bottom section to the top section while the top section is bolted to the head? cause you almost certainly wont be able to that way. you should hang the top section on the studs, connect the bottom section, and then go back and tighten all the bolts
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-18-2003, 01:43 AM
well normally i would try and do that, but since my ac fan is actually hitting my header and the header is all bolted down and everything. so i cant really take off the header that easy. but i guess ill have to try that. i dont really wanan have to dent my oil pan in or go buy another header. and yeah im trying to bolt the bottom to the top while hte top is all torqued down in place
Team Lonely Drivers
Old 06-18-2003, 05:50 AM
redmanjd redmanjd is offline
sounds weird my header went on no problem.
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 06-18-2003, 02:37 PM
what header did u use redman ? what year and stuff
Team Lonely Drivers
Header Problems Gomezy3k S-10 3 10-20-2003 12:46 PM
CAI/Header Problem JWandtheguppies Engineering/ Technical 7 10-11-2003 11:06 AM
d16z6 swap header install Q... 91civicDXdude '88 - '91 Civic | CRX | Wagon | Shuttlee 2 10-11-2002 08:03 AM
header problem 97stratus Engineering/ Technical 9 09-07-2002 09:47 PM
engine swap header? cnycivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 03-04-2002 12:20 AM
