Old 10-30-2013, 11:08 PM
tken35 tken35 is offline
1995 LeSabre - PCM
Can anyone provide some instructions on how to remove the PCM. I found an illustration but when I looked through the glove box there are other things in front of the PCM.
Btw, does this years' PCM have a chip(s) that has to be transferred or does it have to be reprogrammed? Lastly, will I need to get ahold of a GM Tech 2 if it does have to be reprogrammed or will another scan tool work?
Thank you in advance.
Old 11-02-2013, 11:14 AM
Blue Bowtie's Avatar
Registered Offender
Re: 1995 LeSabre - PCM
It's easier if you take the few minutes to remove the glove box door. The photo shows what had to be disconnected to remove the PCM on my '95:
The Following User Says Thank You to Blue Bowtie For This Useful Post:
tken35 (11-02-2013)
Old 11-02-2013, 06:29 PM
Blue,
Great photo, let's hope I can get that far . How is the PCM attached to the firewall? Are there any bolts or screws? I was only able to feel a clip on the top portion and was curious if it just "snaps in"?
Old 11-02-2013, 08:29 PM
Tech II Tech II is offline
Picture looks like the old "red, white and blue" PCM......I think this is the one that you just transfer the PROM....I think the PCM slides out of the plastic holder....just bend back the tabs at the bottom, and the PCM sides down....
The Following User Says Thank You to Tech II For This Useful Post:
tken35 (11-02-2013)
Old 11-07-2013, 07:18 AM
Registered Offender
T-II,
Just an FYI, this one is the enhanced ECM (sometimes colloquially called "OBD-1½") and is has an EEPROM for main RAM without any of the old style back resistor DIPs for limp mode.
Old 11-13-2014, 08:12 PM
petewoods54 petewoods54 is offline
Thankx a million for the picture and where it is!!! I do believe i'm having possible issues with mine!!! U rock!! Thank da' lord I found this forum *thumbs up*
