Old 06-11-2003, 05:12 PM
its_christo its_christo is offline
Question Swapping HX ecu with EX ecu??
I have a 96 5-spd HX, which has VTEC-E. A friend of mine is getting rid of his 96 EX ecu, and i was wondering if swapping the ecu would be at all beneficial. Some people say that it would enable regular VTEC in my car but i wanted to know for sure...
Thanks for the help
Old 06-11-2003, 05:39 PM
HXCivic97 HXCivic97 is offline
Send a message via AIM to HXCivic97
No, the only way to get regular VTEC is to get the EX head in your HX block, or the entire EX engine.
Old 06-12-2003, 09:37 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
if it is free id go for it, you still mioght have some more p[ower out of it, but you will stil have the same vtec system. vtec E is 1 valve to 2 valves i think while vtec is 2 valves to 2 valves higher lift. I am alsoi not certain if the engagement points are the dsame on the EX and HX.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 06-13-2003, 01:56 AM
wheel1856's Avatar
wheel1856 wheel1856 is offline
Send a message via AIM to wheel1856
i suspect that an ecu swap would cause some serious issues. ie: fuel distribution and engagement times that would baffle your engine. you'd have a constant check engine light on, and likely goo for spark plugs and seals after a very short time. if you want the v-tec, get the head.
you could pick up a d16 for not that much...I imagine...and with some turbo...
www.hmotorsonline.com
"Why yes, this is a GS-R."
96 cavalier tranny swap with a 94 sunbird gothmoglord Non-Performance 0 10-22-2009 10:30 PM
b16a2 swap, but d16 ecu/tranny/mounts?!! portaman03 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 09-25-2006 01:34 PM
Z6 Swap w/P28 ECU Question JimCRX '88 - '91 Civic | CRX | Wagon | Shuttlee 4 05-17-2004 09:32 PM
Issues with using JDM Gti-R ECU with g20 tranny willyC Engine 1 03-07-2003 06:53 PM
