Old 06-10-2003, 10:57 PM
doubleF doubleF is offline
just a real quick answer please
does a sohc v-tec motor from a 92-99 civic EX fit into a 88-91 Civic or crx without serious modification. if it does what kinda motor mount would i need.
Old 06-10-2003, 11:01 PM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
It will bolt in using the stock mounts and tranny.....the 92-95 ex is the d16z6 which is ODB 1 and the 96-00 EX is a d16y8 ODB 2, so the wiring for the y8 will be more complicated than the z6....however both can be done fairly easily if your good with wiring.
I'm Jordan
My car is the ugliest one on this board
Old 06-10-2003, 11:02 PM
jusg19 jusg19 is offline
no major mods, you may need wiring changes, but if your talking about the d16z then you can use stock tranny, intake(from your si or you have to swap in from the donor car), and you can use your manifold. I believe you can use your stock mounts since its a d series
Need some real quick help please! mmync Regal 3 03-19-2008 02:05 AM
just some quick advise please blight Sentra | 200SX (USDM FWD) 11 11-04-2004 01:57 PM
How much oil in my Celica ? Quick answer please !!! Iplayloud Street Racing 5 09-22-2003 01:33 PM
Few Quick Questions< Please Answer!?!?!? G20TurboVisionCrew Suspension 2 02-22-2002 01:48 AM
