Old 06-10-2003, 04:05 PM
CivicYoungin's Avatar
CivicYoungin CivicYoungin is offline
Send a message via AIM to CivicYoungin Send a message via MSN to CivicYoungin
CRX Question...D16Z6 swap
when u swap a D16Z6 in a CRX what parts u need to change along with it...do u need to change the transmission etc...what parts do u need to change when u swap it in...
Old 06-10-2003, 04:10 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
I am not certain, but i am almost possitive that everything will go in easily without having to modify anything unless your crx isnt an SI, then you will need the wiring harness from an SI unless you have one with the engine, and you will also need the ECU.
Old 06-10-2003, 05:08 PM
ok...but i got a question what the hell is a ecu?
Old 06-10-2003, 05:47 PM
It is the computer that prety much runs everything. Look under the carpet on the front passenger side and take off the metal cover, and there is the ECU
Old 06-10-2003, 06:08 PM
aight...so when i change the ECU what i change it to?
and how much will it cost?...
Old 06-10-2003, 09:39 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
if your going to use the si ecu its code is the pm6, theres one floatin around in the classified for 50 bucks i believe, but you will aslo need a way to engage vtec
2002 Acura TL Type S
1991 Honda Crx Si
Old 06-12-2003, 04:54 PM
^what u mean bout enage the vtec?
Old 06-12-2003, 07:12 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
your crx doesnt have VTEC so you need an aftermarket unit that will start the vtec process when you get to a certain rpm around 5000rpms, like an rpm activated switch, or a fields vtec controller, etc.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-12-2003, 09:56 PM
where can i get this and how much will it cost?
Old 06-12-2003, 10:03 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
jezza louisa...this has been done a million times....try the search
go to www.4thGenerationCivic.com and look in the engine section. i have up all the links i found when doing my sohc vtec swap
2 ways to engauge vtec. with the pm6 88-91 si ecu + rpm activated switch (from summit) or p28 92-95 Si/EX + wiring conversion harness. the p28 route is more expensive yet, more efficent.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 06-12-2003, 10:07 PM
^lady i think i "love" u just playin...but thanks for tellin me that...
lady i got a question where they say "4g" they mean 4g Civic('92-95 Civic) right?...just worryin so i dont fuck up and get the wrong shit...and when they said get a 4g intake manifold and other shit like that i can buy a aftermarket ones...right?...instead of a stock ones...
Old 06-12-2003, 11:28 PM
amy@af's Avatar
4g = 88-91
5g = 92-95
6g = 96-00
you can buy aftermarket...BUT, beware. you can mix and match d series parts. however i have learned to not mix just anything. so if you plan to use a p28 then get the z6 or y8 intake mani (depending which engine you get). same goes for the distributor (dizzy )
Old 06-13-2003, 06:29 AM
see i almost fuck up with the years...aight thanks...now where can i get the block...i been searchin like hell to find one...and cant find a good site or place to buy it from...
hold up...in the line like this...
5g block have the radiator fan switch at the thermostat housing compared to the 4g which is at the back of the block . You could either just extend the two wires blk and yel/green and then connect it using the 5g connector for the fan switch at the thermostat housing or on" 92 block only", there's a hole plugged up by a bolt on the same spot where the 4g switch is located. Just transfer the 4g switch to the 5g block but be careful not to break the two prong connectors and put high temp sealant before installing it...
that means i still need the 4g engine that came out of the CRX?...if i do...i'm fuck...cuz me and my bro found a CRX without an engine...and goin to buy that bitch...like 2 weeks from now...if it still there...tell me cuz i'm confuse...and let me get this clear 2...dont a block post to come with pistons, etc., cuz i think i found one close to me with piston, etc...i dunno, i'm alittle slow on swappin engine...sorry for ur time...
Old 06-13-2003, 10:14 AM
95 d16z6 into 91 crx si eray_92 How-To's and Walk-Through's 0 08-31-2010 04:24 PM
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 07:48 PM
for those doing mpfi swap on crx or d16z6, d15 vtec swap Scott82 Classifieds 3 04-21-2005 06:37 PM
CRX Sohc D16Z6 Swap Q&A Scott82 '88 - '91 Civic | CRX | Wagon | Shuttlee 15 02-18-2005 07:51 AM
D16Z6 swap in 91 crx si HELP?prices up for work done Bori '88 - '91 Civic | CRX | Wagon | Shuttlee 9 04-03-2004 08:05 PM
