View Poll Results: Which tranny would you use
Hf Stock tranny, work good? 0 0%
Si upgrade, Worth the trouble? 3 100.00%
Voters: 3. You may not vote on this poll
Old 02-15-2005, 04:26 PM
Scott82 Scott82 is offline
Lightbulb CRX Sohc D16Z6 Swap Q&A
OK Now that i have the wiring figured out, i need help with the tranny. Ok I am putting the D16Z6 into a CRX Hf. If i bolt the 91 Civic SI tranny to the motor will i have to make any mods to shift linkage and will i have to get a differ CV Axel? Please help, i think with this last piece of info, i'll be readdy to get the job done. i am very excited about going vtec and i just want to make sure i am doing all of this the right way so it all works the way it should. Thanks Scott
Old 02-15-2005, 05:48 PM
Re: CRX Sohc D16Z6 Swap Q&A
Anyone that knows anything would help, I want to do it myself to make sure its done right just kinda need to know the directions in a way
Old 02-15-2005, 06:23 PM
kingpinn's Avatar
kingpinn kingpinn is offline
you need to get a p28 i posted something like this a few days ago check old threads its there
Old 02-15-2005, 06:25 PM
Do you know anything about the shift linkage and cv axels if i change out the trannys
Old 02-15-2005, 08:16 PM
thanks for the wiring help just need the tranny info. I am a good mechanic, just never put a motor that didn't come in a car into a car, and making sure i am doing this the right way since it is my car an all. Thanks all that help!
Old 02-15-2005, 08:35 PM
TypeGsR TypeGsR is offline
Banned
i dont no u might u might not look at the shift linkage and look at the slave cylinder make sure they are i the right place
Old 02-15-2005, 08:37 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
As long as your 89 HF was a 5spd which they prolly all were i dont see you havig any probs with si upgrade unless your si upgrade is comming from a 88 si cause they had a different spline count on the input shaft
Old 02-15-2005, 08:50 PM
Apreciate the help guys, i plan on using the 91 civic si tranny because it's a cable tranny like the one i have already, at least thats what i have been told, if any differ let me know. I am just trying to do this with the least amount of mods cause i am doing it my self and i want to make sure everything fits together just right. Make a nice clean job out of to where it looks like that was the way it came. I just want it to look good and do good if ya know what i mean
Old 02-15-2005, 11:29 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
if you use the Si tranny, the shift linkage will work the same. the spline count on the axles however, that is different. the HF uses the smaller size axles, so either continue using your HF axles and hope they hold up (they should, its not like you are going crazy with power to them), or swap your front knuckles to Si or 4door EX knuckles to use the bigger spline size.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 02-15-2005, 11:37 PM
What would you do if you were doing this for a car for your self and what all would i need in order to make that conversion if it is much more reliable or if it dosn't make a difference on reliability let me know. Cause my hope one day is for either a turbo or supercharger so for the long run what do i need to make it work right.
Old 02-16-2005, 02:14 AM
Hybrid1990crx's Avatar
those HF axles are not going to work on the Si tranny, HF axles have 24 splines and Si have 26. So they wont fit. And yes your shiftlinkage will work just fine.
And not to burst your bubble but don't be too excited about the vtec on that z6, its not going to hit that hard like on a dohc, its just more of an extention of the powerband.
Old 02-16-2005, 09:10 AM
Thanks for the help. what all do i need to make thhe axels fit through the rotors and what not. Or would you just use the HF Tranny instead?
thanks Scott
Old 02-16-2005, 09:40 PM
I would not use no piece of shit HF tranny, its geared like shit. all you really need is to have new knuckles pressed into your hubs, but its usually easier just to get new hubs.
Old 02-16-2005, 09:58 PM
I am thinking for the time being to use the HF Tranny so that i will have enough $$$ to get my body work finished and painted and then when i get enough $$$ again i think i want to put the whole 91 CRX SI Brake system so i can have 4 wheel disk brakes and then go ahead and change the front hubs and axels so i make sure and have a good factory brake balance between front and back. Does that make any since to anyone or am i just lost here.
Old 02-17-2005, 01:42 AM
i think you should get the tranny before you do paint. you'll thank yourself later.
