Old 06-10-2003, 12:53 PM
hatflyer hatflyer is offline
Air Conditiong-Old vs New
A mechanic is willing to put new freon into my R12 (old) system, without converting my older system. He said it probably won't be quite as cold, but works. Is he right?
I have a '93 Taurus.
Thanks,
Jim
Old 06-10-2003, 02:16 PM
CraigFL's Avatar
CraigFL CraigFL is offline
I would use the R12 if you aren't going to convert it.
Old 06-10-2003, 02:19 PM
Craig,
Thanks for the reply. Can you say why I should use the old freon?
Thanks again,
Jim
Old 06-10-2003, 02:24 PM
Steel's Avatar
Steel Steel is offline
the old R12 actaully cools a lot better with less compression than the R134 these days. Problem is, its really hazardous to the environment, that's wy they've been switching to R134. So you give up a little cooling for the ozones sake.
Old 06-10-2003, 02:44 PM
Is R12 still available anywhere?
Old/New Corvette ghetto7o2azn Graphic Manipulation 9 11-01-2005 09:42 AM
15yr old new tuner but experienced 95dxcivic Introductions 30 09-03-2004 10:58 PM
Old New Kid jettanut Introductions 0 07-29-2004 10:49 AM
New Member Old New car 88 325is letsgetiton 3 Series 2 09-09-2002 09:00 PM
