Old 12-30-2003, 02:57 PM
hondahead420 hondahead420 is offline
Send a message via MSN to hondahead420
Question help with head swap d16z6 on d15b2
i have a 90 hb that i put a 94 ex head on the problem is that it wont rev past 3200ish it bogs down i do not have the vtec hooked up yet i have a rs type vtec controller but i am very confused on how to hook it up ..i dont have factory wiring please help if you have done this swap
Old 12-31-2003, 08:02 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...kinda sounds like either an ignition timing issue...or cam timing issue..possibly....
SOLD!
Old 12-31-2003, 10:36 AM
91civicDXdude's Avatar
did you do your multiport conversion correctly? would the car rev correctly after completing multiport and just not when you installed the VTEC head? What ECU are you using?
Civic d15/16 head swaps snutmajor '96-'00 Civic 0 03-29-2009 11:42 AM
Need help with head swap!!! dspencer81801 Engineering/ Technical 0 12-23-2003 09:10 PM
help w/ head swap hondacivicjunkie Engineering/ Technical 0 08-25-2002 03:55 PM
