Old 06-10-2003, 06:44 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Possible carb setup
My 2 bro's have been talking me into keep the 1.3 DX instead of getting a VTi, and changing the engine with a ZC , they said to start with i could change the main engine and gearbox and use the carb setup i have if it will fit, if not i may be able to fit the carbs off a 2.0 twin carb prelude if the single carb isnt man enough for it, becaus ei can get a custom inlet manifold made up VERY cheap from a Bri's friend
I would of course change it to injection eventually because i could run CAI and a lot more power but would this motor run ok with a similar setup ???
Cheerz
Jim
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 06-10-2003, 08:02 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Some JDM ZCs came with twin-carbs, but they usually only pumped 115bhp not 130 I think. Best bet is tracking down a Jackson Racing Webber manifold and then bolting up twin 45mm Webbers
But I'd just wire in the PGMFi if it was up to me I don't think the Accord/'lude twin keihin setup matches the ZC head.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 06-10-2003, 08:03 AM
Civic Jim's Avatar
ah right , how much would a set of twin webbers be then roughly ? 2nd hand
B16A1 I/H/E
4TH GEN UK SITE
Old 06-10-2003, 08:10 AM
Setanta's Avatar
Over here, about 400-600 bucks Aussie - halve that for greenbacks and NFI for pounds
You'll prolly need to choke them to 40mm and run a gasket kit through them, but it's a good option. I ran them on an EW2 12 valve motor bolted into a first gen Civic. Thirsty buggers though and noisy as all hell sitting against the firewall. Hell, even the twin Dell Orto's I ran on an EB3/EN1 hybrid motor were noisy and they were only 35mm throttles.
'99 PY DC2R
'85 BBS BMW E30
Old 06-10-2003, 08:11 AM
Civic Jim's Avatar
ah right, well it may be an option then , i got no ££ at the mo but i am keeping the 88 so i can take my time on this one now
B16A1 I/H/E
4TH GEN UK SITE
Old 06-10-2003, 08:14 AM
Civic Jim's Avatar
how long do u think it would take to do a complete swap including wiring loom, and everything to change from my 1.3 carb to a 1.6 injection, if i already had the ZC ripped out of another car
B16A1 I/H/E
4TH GEN UK SITE
Old 06-10-2003, 08:22 AM
Setanta's Avatar
Front cut to car - if you had all the reference points for ancilleries and used the existing ZC loom - I'd say 3 days tops, but 48 hours would be a good run at it to make sure you got it all right the first time
'99 PY DC2R
'85 BBS BMW E30
Old 06-10-2003, 08:23 AM
Civic Jim's Avatar
wot other loom would i use, coz my carb aint ECU controlled is it so i would have to start from scratch wouldnt i
B16A1 I/H/E
4TH GEN UK SITE
Old 06-10-2003, 08:24 AM
Civic Jim's Avatar
that wasnt menna sound nasty either it is a question not a remark
B16A1 I/H/E
4TH GEN UK SITE
Old 06-10-2003, 10:02 AM
Setanta's Avatar
Yep - personally I'd reef the GL loom completely and drop the Si loom in its place. Keep it simple and straightforward by sitting the cars next to each other if you can
'99 PY DC2R
'85 BBS BMW E30
Old 06-10-2003, 10:03 AM
Civic Jim's Avatar
WELL THE THING IS I WILL PROBLY JUST BUY THE ENGINE AND PARTS I NEED NOT THE WHOL CAR COZ I GOT NOWHERE TO STORE IT REALLY
B16A1 I/H/E
4TH GEN UK SITE
Old 06-10-2003, 01:00 PM
antiguabill's Avatar
antiguabill antiguabill is offline
my 1.4 gl has twin carb.... would that be worth anything?
Old 06-10-2003, 03:02 PM
D15Bitch's Avatar
D15Bitch D15Bitch is offline
Thumbs up Carbs rule...
I just planted the ZC SOHC dual carb engine from a '93 'tegra into my 4G4D after throwing out the D15B3 (single carb, exact specs as USA DX model).
I have to tell you, although they say the dual carb engine is "only" 112-115 HP, if you tune the carbs right, you could easily get to 120+HP. Before doing stuff like a cam, compression, headers and exhaust system. My D15B3 was not standard by any means, but this ZC, even as standard, promises a lot more fun. I can't wait to start playing. (I have a thing about SOHC's and carbs, like to prove their worth...)
Of course, everyone knows about Bizi Ezerioha, of Bizimoto, the NHRA import dragger with the "fastest all motor honda in the world" - it's a 1500 8 valve dual carb unibody CRX.
impressive...
Few questions about my Electric Q-Jet Carb caffeineaholic Caprice 5 03-06-2010 11:38 AM
CIS vs. Dual carb setup for 83 GTI jettaboy1884 Rabbit 3 09-09-2004 04:32 AM
Possibly future setup? Zonathin Forced Induction 2 10-23-2003 06:04 PM
What is a carb setup? doug294 '88 - '91 Civic | CRX | Wagon | Shuttlee 12 05-24-2003 03:45 PM
? about possible 300zx setups z0n3x 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 10-30-2002 12:28 AM
