Old 06-09-2003, 10:15 PM
91civhatch 91civhatch is offline
quick question guys
Im puttin the mpfi swap on my dx 1.5... I want to swap the entire harness in but i know it doesnt mount right up so can i just run the wires that neeed to be run from the ecu and tap them into the harness????
Old 06-10-2003, 12:16 AM
2000dollarZCbs 2000dollarZCbs is offline
Send a message via AIM to 2000dollarZCbs
i have done EVERYTHING with wiring in my car, most important, what harness are you swapping in? cause putting an SI harness WILL NOT WORK, NOT EVEN WITH THE CABIN ONE TOO.
*TeamchokE* i love to support my boys, www.HBultimatetraining.com ,
www.chrisbrennan.com ,
www.zentraediracing.com . all my boys.
Old 06-10-2003, 12:25 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
its kinda true. i used an SI engine harness, the interconnect plugs from an SI body harness, and the interconnect plugs from my STD engine harness. i used the interconnect plugs to make a subharness. its the easiest thing, cause now i can unplug my motor from a few plugs, and pull out. theres no direct wires to the ECU, which means no cutting them if you ever have to pull the motor, or no unplugging every damned sensor like on nissans.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-10-2003, 01:29 AM
it was from an si so what im going to do is make a harness out my dx might take alil longer but i think it shouldnt be that hard....Thanks guys if i need ya ill post again.....
Old 06-10-2003, 01:38 AM
91civicDXdude's Avatar
an si harness will most definately work, but it is a pain in the ass to change over the entire car wiring harness.
Old 06-10-2003, 01:44 AM
so the way im doing it by tapping into my dx harness Basically creating my own harness is the best way?
Old 06-10-2003, 01:46 AM
its defiantely the quickest/easiest way.
Quick question guys? Sen Sen Blazer 2 05-04-2005 04:32 PM
Quick Question guys on walbro 255 fuel pump gotboost2ggst Off-Topic 1 01-01-2005 06:02 PM
Quick Question Guys ro62186 Tires and Wheels 1 02-29-2004 06:24 PM
Quick question for you guys. 88AccordLXi-SteveO '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 10 04-26-2002 11:50 AM
Quick question fro Skyline guys USA Racer General Discussion 14 12-24-2001 11:08 AM
