Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-03-2013, 12:52 PM
94HeavyChevy 94HeavyChevy is offline
Replacing front wheel stud
Is it possible to replace a wheel stud on a 94 caprice classic. the rotor and hub are all one piece. i was about to replace my pads and one of my studs broke. can i replace it or do i need to replace the whole rotor and hub?
Old 10-03-2013, 06:26 PM
j cAT j cAT is offline
Re: Replacing front wheel stud
take the hub/rotor off support the hub solidly and drive out the stud. then install the replacement stud. now it is possible that you may not find a replacement stud. then I would call the scrap yard and get another rotor. even though these are old now you would be surprised that most scrap vehicles have new rotors. I would even take the wheel bearings complete. then repack then and install new seals. I would take both rotors from the scrap yard vehicle if they look real good..
studs break because the tire shops use air guns. they also use worn sockets these cause you pain !
Old 10-05-2013, 11:06 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
You can get the proper stud at any parts store - at least you can here in Arizona (don't see why that would be different anywhere else). Both Autozone and Oreilly's have them.
J cat has good advice regarding the wheel bearings - since you need to pull the rotor off anyway.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-08-2013, 07:00 AM
cant believe how easy this actually was! i let it soak in penetrating oil over night (dont know if this helped or not). With the rotor still on the car I gave the stud 2 taps with a small metal hammer and it came right out. i could not get the new stud in with my hand or with vice grips so i used a 18inch magnetic wand and was able to find a small space to get the new stud in. I tapped it with a long screw driver then pulled the stud through using a lug nut and impact gun. Changed the pads on both sides and saved alot of money not buying rotors. Got the stud at NAPA for 1.69. Thanks for all your help guys!
Old 10-08-2013, 12:21 PM
rkvons's Avatar
rkvons rkvons is offline
Beautiful!
Old 10-08-2013, 04:23 PM
what you should have done was remove the rotor. hammering the rotor when on , is not good for the wheel bearings.. since it come off easy then you probably will not have any bearing issues.
