Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-09-2003, 09:08 PM
mscmor mscmor is offline
pistons on rear calipers
Recently I purchased the REAR pads and rotors for my 2000 se max.
Everyting came apart ok. I am having a really hard time pressing in the piston on the caliper. They mention to do it with a c-clamp., which i tried. I actually ruined a 6 inch clamp trying to move the piston back.
Does anyone have any ideas or did I miss something. A manual says to compress the piston while everyting is assembled. You are suposed to just fit the clamp over the whole assembly and use the pad rotor and pad to press against the piston and back it off.
A manual I have mentions to remove some of the brake fluid from the reservoir before pushing back the piston. I took everyting apart on both REAR sides, including the bracket that holds the cliper. Everything came apart ok and looked alright.
What would the chances be that I have two seized REAR calipers? Is there a trick I don't know about. Also, I was thinking about loosening the little bleed valve on the caliper. Does anyone know if that is a necessary step?
Thanks.
Mike
Old 06-09-2003, 09:16 PM
Dean R Dean R is offline
rear brakes
The piston screws in to retract.
Old 06-09-2003, 09:31 PM
would that be a right handed thread, i.e. ccw to retract?
Old 06-09-2003, 09:44 PM
clockwise
clockwise to retract I used a tool from an auot parts store.
Old 06-13-2003, 09:59 AM
Waveridr85 Waveridr85 is offline
Registered User
or you can use a set of needle nose pliers
Old 06-13-2003, 11:33 AM
glregez glregez is offline
Smile Couple tricks
I just did the front and rear pads on my 1999 Maxima last weekend. First time for me on the Nissian, but many times on other cars. After replacing the rear pads and all the other parts, screwing the piston back and aligning it correctly, I still couldn?t get it align for the bolts. It took me about a half hour to realize that the ?floating pins? ( I am sure that?s not the correct name) have to be turned correctly so the flat side allows the unit to align so you can put in the bolts. It was driving me nuts for a while.
The front pads also require you to ?snap? them in. Align them, push down on the spring device on the bottom at an angle and slide toward the rotor. Another trick I had to learn.
Now I could replace all these pads in about hour, but by the time it needs it, I will have forgotten all.
Car had 40K miles, rear pads gone and the front about half gone.
Old 06-22-2003, 10:14 PM
osteridge osteridge is offline
Send a message via AIM to osteridge
kinda late but for what its worth
i replaced the back pads on mine about two weeks ago and to get the caliper to retract i had to get a tool from the local nissan dealerships where my uncle is a mechanic (great connection for "cheap" parts ha) it connects to a ratchet preferabbly one with an extension and skrew it in clockwise and it goes back... from what i hear you can get this part from auto zone
Peace,
Alen
Old 07-19-2003, 07:59 PM
after getting the tool at autozone i did the work on the rears in about an hour of so. thanks for the info!
Old 07-19-2003, 08:06 PM
not a problem thats what im here for ha
Peace,
Alen
front caliper issues 92 maxima aerrick_matthew General Discussion 0 09-28-2009 11:54 PM
Rear Caliper Piston Not Going Down tamango98 Taurus | Taurus Wagon 5 06-13-2007 08:12 PM
Replacing Rear Calipers On 98 GMC Jimmy 4x4 rear disc CanukGMC Jimmy 6 05-06-2006 11:04 PM
95 rear caliper/piston 95luder Prelude 2 06-02-2005 04:43 PM
Single Piston Floating Calipers vs 4 Piston Non-Floating Calipers IOIOOI M3 0 02-09-2002 09:30 AM
