Old 06-09-2003, 07:47 PM
alphalanos alphalanos is offline
Diff. between turbo and supercharger?
whats the difference
96 EJ6. Future home of boosted B18C1.
Old 06-09-2003, 08:17 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Turbo: This is a device that is driven by the exhaust. The exhaust causes a turbine to spin. There is a shaft connecting it to another turbine which then forces air into the cylinders. This uses no power to make power. Also because of this you will have turbo lag allowing you to retain good gas mileage when you aren't getting on the gas.
Super: This is a belt driven device. It has to use some of the power from the engine to force air into the cylinders. Also the power is instant as soon as you hit the gas; this will affect your gas mileage.
I feel that the turbo is better but it is all personal preference.
Old 06-10-2003, 10:34 PM
454Casull 454Casull is offline
A turbo does take a little bit of power, but not so much as a mechanically-driven supercharger. Remember, there's nothing in life that's free.
Mechanically-driven superchargers (either by belt, chain or gearset) are driven off the crankshaft and directly pressurize the intake charge with a compressor wheel (a centrifugal supercharger), two 3-lobed rotors (Roots supercharger), or two screws (Lysholm/twin-screw supercharger). Because the crankshaft drives these kinds of superchargers torque is spent running this as an accessory, much as turning on A/C slows down weak engines.
Just a little reminder as to why I wasted time putting "mechanically-driven" in front of "supercharger" - turbochargers are classified as superchargers. Kind of like how squares are always rectangles but not all rectangles are squares.
EDIT: I forgot to mention another supercharger type - the Wankel. Yup, before the rotary was an engine, it was a pump.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 06-10-2003, 11:44 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
True, but a large portion of the power to drive the turbo would have been wasted otherwise. All that enthalpy in the exhaust... Turbos are wonderful for engines that aren't compression (knock) limited. They're a whole lot less impressive in applications where max cylinder pressure is severely restricted (ie gasoline engines). A good turbo improves the overall efficiency of a diesel engine (vs no turbo at all), which is a sure sign that it's giving "work for free" when compared to blowing the exhaust energy straight out the pipe.
There are some applications where a supercharger can yield "work for free" too. Some Miller cycle engines take advantage of a supercharger to facilitate over-expansion of the cylinder gases. The intake duration is shortened, so the compression stroke is effectively shortened, but the intake charge is denser (due to the S/C), so the power output is still good. Overall efficiency is said to be pretty good.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 06-10-2003, 11:49 PM
Sean Sean is offline
A turbo can decrease the ease at which exhaust comes out, but if you have the proper equipment you can overcome it. Anyone want to explain blowoff valves and wastegates? im too lazy
--------------------------------------------------- My signature line.
Old 06-11-2003, 12:03 AM
..but it ends up giving you positive pumping work, so who cares?
no.
There's an article about all this in the "articles by Texan" portion of this site.
Old 06-11-2003, 11:37 AM
Yeah, the Miller cycle engines are pretty interesting. Compression does take a lot of energy to accomplish.
Old 06-24-2003, 10:48 AM
rxtacy rxtacy is offline
wastegate regulates amount of exhaust allowed to drive the turbine (boost), and the bov releases pressure from the system when there is excess air headed for the tb (like when you let off the gas real quick). see, that wasn't so hard now.
the difference between Turbos and an "electric supercharger." Hypsi87 Camaro Discussions 10 11-03-2004 08:49 PM
Torn between turbos and superchargers? Read this! Thepeug Forced Induction 6 03-14-2004 09:02 AM
diff between turbo z and non turbo z pedezilla 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 4 09-22-2002 05:00 PM
Diff between H22 and H22A super 96 accord Engineering/ Technical 6 03-11-2002 12:10 AM
