I just recently ordered a cold air intake system for my '01 GT and figured while installing that, it would be a good time to put in a new throttle body. What kind is best, I was looking at BBK, and what size is best, the 70mm? Thanks for the help.
i was thinking about putting on 70 mm on my car, i can't imagine why not - for some reason everyone seems to keep it at 70 or 65. greater then 75 won't really do anything with out crazy mods. be sure that you do more then just a larger throttle or else the benefits will be minimal. and too big of anything on the intake or exaust could result in "diarrhea of the engine" - that is to say too much flow that leads to a loss of low end torque.
oh yea - don't forget to get the appropriate spacer to go along with the throttle body. |
70 is fine. Also, look into getting another mass air meter. Its supposed to help out alot!
Under the same driving circumstances, would the larger throttle body and mass air sensor hurt gas mileage at all?
when in doubt, throttle. |
I havn't made the change myself, but it would make sence to me if gas mileage increased slightly. On one hand the more air makes for a better fire, but on the other hand what the fuck do i know?
but keep in mind that just replacing the throttle body and spacer won't suddenly open your car up, you've got to balance it with a change in the exaust manifold or a post-throttle body intake flow enhancer. big words are fun. |
TB,CAI, MAF all will help but also big gains can be had by potring and polishing that pretty metal box that sits on top of your plastic intake manifold.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
I don't think a bigger MAF hurts anything if its the right size. Shitty injectors (clogged, otherwise), overreving, racing the fuck out of it, gears, and prolly cams and other shit would hurt your gas mileage.
Just spray the damn thing. |
yo los - you keep saying "just spray it" what does that refer to?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
1990 Mustang LX 5.0 25th anniversary Current Mods- Pro-m 77mm mass air flow sensor w/K&N cone filter 24lb. fuel injectors w/ adjustable fuel pressure regulator & pressure gage 65mm FMS throttle body w/ 67mm EGR Spacer Ford GT-40 intake manifold ported to match cylinder intake runners Idle speed plate on throttle GT-40 cylinder heads Cast iron ported and polished intake & exhaust runners Race valve job milled to increase combustion Steeda motorsport street/strip #18 custom grind cams Roller Rockers BBK full length ceramic headers Short H pipe w/ high flow cats walker dynomax stainless muffler system (cat back) Hurst Chrome Shifter 355 ring & pinion rear axle Aluminum Radiator Underdrive pullies Saleen Race Craft Springs Kenny Brown Subframe Connectors FMS King Cobra Clutch 110lb/hour fuel pump |
i know that the block can hang with NO2 if the bursts are short, be sure to run extra high octane, 92+ to be certain that all of the no2 is burnt up. In california the highest grade you can get at the pump is 91 and my friend's old 67 gt didn't burn it all up and some excess no2 got into the upper manifold and blew that shit off.
Highflow knows all about this shit - wait for him. |
My best friend runs a 150 shot. He recently took the motor apart for port/polish, just overall head rework. He didnt' have a problem, only one backfire which crumpled his K&N filter as it smashed into the front of the car in the engine compartment. As soon as that's done, he thinks he can push a 175 shot.
I think he's going to melt his heads, get pissed off, and start bitching about how his life sucks.
I don't see a problem with running a 50-75 shot occasionally, depending on the motors current condition and all. If the motor had high miles and small problems, I would think twice about it.
I think ZEX makes the easiest and safest kit to use. It's just nitrous and not fuel/nitrous mix. Take a look at this, here's what happens when you get a nitrous backfire. Ouch!
I was actually planning on getting the zex kit, and the highest gas ive seen around here is 93, and its hard to find. Its usually 92 though. My intake & exhaust runners have been ported and polished.
A stock 302 block can handle up to 150hp shot if you get the right kit. Avoid any wet system that is not a plate design. Also run highest octane avialable, step colder non-platinium plugs, bump timing down 2 degress per 100hp added.
Hi-flow: porting that intake box gives around a 15hp gain. If anyone is interested let me know I do them for $40.
