Old 07-07-2013, 09:19 AM
Some_Kid's Avatar
Some_Kid Some_Kid is offline
Need a very fine silver
Hi guys I was wondering if any of you had some suggestions on silver paint. I want a silver that looks to scale. One that looks good not only in light but in shadow as well. Most metallic paints are not fine enough for this. I am very aware of Zero paints but if at all possible I was wondering if any of you knew any paints, perhaps ones that I could get formulated in the states or maybe find at autozone?
I'm building an xj220 and Im going for a silver body. I know all about Tamiya's gloss aluminum but it has given me fits in the past and I would rather not deal with that paint. Tamiya Mica Silver is much easier to paint however the grain isn't quite as fine.
Metallic paints need a very smooth surface to lay down on and I'm pretty good at prepping surfaces but I would also like a silver paint that doesn't show the underlying texture of a surface quite as easily as Gloss Aluminum or Mica Silver do. I am considering getting the paint matched in a spray can(Spa Silver), but there is no guarantee that the actual silver color is fine enough in scale. Thanks for any advice and suggestions.
Old 07-07-2013, 09:28 AM
viperofoz's Avatar
viperofoz viperofoz is offline
Re: Need a very fine silver
You might want to take a look at Tamiya AS-12 (from the aircraft spray range).
Its a nice fine silver that goes on really smoothly and covers very easily, it dries to a satin finish so you will need a clear coat (TS-13) but I find it works so much nicer than TS-17 Gloss Aluminium.
I also use this stuff as a sealer sometimes over filler and when needing to stop red pigment bleed .... like when painting Ebbro's Lotus 72C white.
Regards, Dan
Edit... Here's the AS-12 used on a Toyota 86, showing how fine and even it is. In this application I used it to seal some filler and as a base for the Metallic Orange topcoat, but it could just as easily be cleared and used as the finished colour..
The Following 2 Users Say Thank You to viperofoz For This Useful Post:
Some_Kid (07-07-2013), tonioseven (07-11-2013)
Old 07-07-2013, 10:06 AM
Vric's Avatar
Vric Vric is offline
I use vallejo paint with great result. The "air" Line is prethinned for airbrush and the flake are very small.
Alclad is also quite good
The Following User Says Thank You to Vric For This Useful Post:
Old 07-07-2013, 01:28 PM
turbothirtytwo's Avatar
turbothirtytwo turbothirtytwo is offline
super silver C159 from gunze?
The Following User Says Thank You to turbothirtytwo For This Useful Post:
Old 07-07-2013, 08:24 PM
935k3's Avatar
935k3 935k3 is offline
Whatever silver you use try a small amount of gloss white paint mixed in. It will look smoother and less grainy. It looks like the silver used on Porsche and Mercedes race cars when done this way.
The Following 2 Users Say Thank You to 935k3 For This Useful Post:
Old 07-07-2013, 08:33 PM
Some_Kid's Avatar
Regards, Dan
Ah now that looks like it could be the ticket. Have you actually tried painting a body and clearing it with just this color? Any kind of changes with a clear coat? Compared to Gloss Aluminum for instance, do you find that it has a different "color" so to speak? Does it look finer or about the same as a perfect ts-17 paint job? Sorry for bombarding you with questions, just want to be thorough.
That's really quite an interesting suggestion. I take it you have good results? Do you get a vastly superior finish?
Never thought of Vallejo air brush silver. Though I wouldn't be surprised that they are as good as their brush paints. They are easily becoming one of my favorite suppliers. Their brush speed assembly so much faster.
Old 07-08-2013, 12:18 AM
viperofoz's Avatar
Yes, I have cleared over the AS-12 before with excellent results, but as with ANY metallic, you need to avoid bombarding it with heavy, wet clear coats as this re-softens the metallic particles causing them to sink and therefore darken the colour or make it blotchy and uneven.
Build up the clear with light coats and you shouldn't have any problems.
I also agree from experience in the 1:1 auto painting industry that adding a little white could give you a more in-scale effect with silvers, but just be careful not to add too much as it will completely "kill" the metallic effect and just give you a washed out looking grey if over done.
But definitely worth experimenting with.
Regards, Dan
The Following User Says Thank You to viperofoz For This Useful Post:
Old 07-08-2013, 06:19 AM
ZoomZoomMX-5's Avatar
The airbrush is your friend.
My current favorite silver is Gunze #8 silver, the bottled solvent-based paint. It is a very fine metallic, very much "in scale". Clearcoat w/Gunze clear, or TS13 if you can find it, or use U-Pol clear (that's what I've done).
Another option is to mix some Testors lacquer silver chrome trim with some clear, then add a final clearcoat. It's another incredibly fine silver. This was my go-to in-scale silver for years, when shooting enamels. It works the same way and dries faster w/o yellowing, when using the newer lacquers.
My Fotki Album
The Following User Says Thank You to ZoomZoomMX-5 For This Useful Post:
Old 07-10-2013, 06:36 PM
Some_Kid's Avatar
Well guys I think im going to order some as-12 to experiment with but I think I may actually man up and try airbrushing ts-17 to give me more control over the paint. After looking at ton394's lexus LFA I could not believe how stunning and real that ts-17 paint job looked.
http://www.automotiveforums.com/vbul....php?t=1065091
My question is to those who have airbrushed it before. Is ts-17 ready to spray once decanted? Will I need to thin it? Could I use regular lacquer thinner from a car parts store? I have the equipment to do this job right. I have an Iwata Kustom CS airbrush in addition to their CR air gun. I've got a compressor with adjustable PSI too.
My thinking is that if airbrushed gloss aluminum is anything like airbrushing their acrylic aluminum it should not take to many coats to get full coverage.(i do know the difference between lacquers and acrylics). Leaving the edges sharp and the paint thin and smooth. The goal would be to get a thin even coat. I'll worry about the gloss coat later.
Old 07-10-2013, 06:53 PM
drunken monkey's Avatar
Razor Sharp Twit
you don't really need to gloss TS17
AF's Guidelines
Read them.
Old 07-10-2013, 07:56 PM
Some_Kid's Avatar
As my first time airbrushing it, I think may actually need a clear coat. I'm going to use testors one coat, perhaps airbrushed as well. I have the tendency to burn through in the polishing process. What PSI numbers should I be operating at? 18-25?
Old 07-11-2013, 12:36 PM
Zonic2001's Avatar
Zonic2001 Zonic2001 is offline
How much white versus silver? Percentage wise? 90% to 10%? I will be doing a Mercedes C9 later.
Old 07-12-2013, 05:57 AM
definetly use some clear, that LFA wouldnt look taht good if there was no clearcoat, silver paint is harmfull when you want to take of some dirt or so...
Old 07-12-2013, 10:24 AM
All TS paints that I decant require some thinner.
I always have Mr. Color Thinner (or Leveling thinner), or Tamiya lacquer thinner, on hand, and add a few drops to the mixture so it sprays out smoothly. Remember that an airbrush is applying the paint in thinner, finer layers, and the paint was mixed initially by Tamiya to be applied through the spray can at a much higher rate of both paint and pressure.
I clearcoat nearly every gloss final color. You want to buff/polish clear rather than color most times, especially metallic/pearl finishes. I prefer black w/o clear, but it needs to be sprayed thickly and you have to avoid burning through edges when polishing. I also find Tamiya paint to be rather soft, doesn't hold up terribly well to a lot of handling while building. I don't miss TS 13 whatsoever, aside from the ease of polishing w/Tamiya compound. Gunze solvent-based clear is much more durable, but I'm decanting U-Pol power can clear these days, it requires even more thinner but is a very durable finish and it dries quickly, and is very economical to use, especially vs. TS 13.
My Fotki Album
Old 07-12-2013, 09:25 PM
wadny wadny is offline
I've had really good results with Model Master Metalizer Aluminum non-buffing. I did a Sauber Mercedes C9 with it that turned out great with a 2-part clear over it. I've always liked how the Metalizer paints go on with an airbrush.
