Old 05-18-2013, 02:58 PM
SRC1968 SRC1968 is offline
Angry 2006 grand caravan water pump, engine light
Can someone please help me? I had to replace the water pump on my dodge Grand Caravan, which was challenging, but i got it done. But now the engine light is on.... why would that happen? i did take off the filter hose, and unpluged the cord to move the air filter housing, but, i plugged it back in when i re-hooked everything up. So now i am nervous that i did something wrong.
any clue why the engine light would come on and stay on? water pump works, put coolant in etc.... no leaks.... so now i just need to figure out the engine light.
thanks in advance for any suggestions.
Old 05-19-2013, 12:11 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2006 grand caravan water pump, engine light
"any clue why the engine light would come on and stay on?"
Won't know until you determine what code the PCM has stored to make the light come on. AutoZone or the like will connect a scanner and read your codes for free or you can cycle the key from acc or off to on (not start) three times ending at the on position. The code will appear in your odometer display.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 05-19-2013, 11:44 AM
Thank you RIP for responding.... i deeply appreciate it.
code says PO113. the tensioner didn't change, i just pulled it down, with a tension rod bar.... teh belt is on correctly. so why would this come on?
Old 05-19-2013, 05:53 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Your intake air temp sensor may be disconnected. http://www.obd-codes.com/p0113
https://www.google.com/search?q=inle...h&tbo=u&source
Old 05-20-2013, 11:56 AM
RIP, everything was connect. however, one of my buddies asked me if i started the car BEFORE i connected everything, then connected everything and started to drive it.... i said yes. he said that is why the engine/code is on. that i had to clear it out, and then it will be fine. we did, and so far, everything is good. i didn't know if you start the vehicle with things not connected, and then connect it that it wouldn't see or register that it is now connected, and then shut the code off somehow. so thank you for your time to reply.
very appreciative....
Old 05-20-2013, 01:26 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Yup, your buddy was spot on. It would have reset after a few drive cycles but who wants to wait for that. Glad to hear your headache is history. The good thing is you learned a little more about how these wonder wagons work. That's always a good thing.
Old 05-20-2013, 04:36 PM
exalteduser's Avatar
exalteduser exalteduser is offline
Goober
would this same theory apply to me plugging in the wire to my cruise control after i noticed it wasnt working? Im not getting a code but it still wont work. maybe if i unhook the battery for 10 mins and re hook it up?
(had some body/exhaust work done and they forgot to plug it back in at shop)
1991 Jeep Wrangler 4.0 (3rd child or 2nd wife)
1999 Chevy Suburban 1500 5.7
2005 Toyota Rav4
1994 S-10 Blazer 4.3L "W" "Dead and gone"
Old 05-20-2013, 06:52 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Probably not. That trick works on microprocessors but the cruise servo doesn't use them. Sure no harm in trying though. Not sure about an 07 but there may be a vacuum line they forgot about too.
Old 05-21-2013, 04:39 PM
Goober
there is a little one direct from manifold on, the a larger one on the back with a T and those all appear to be on/tight
EDIT: I did the battery thing and it works now. never say never. glad I read this post. Thanks!
2005 Toyota Rav4
Old 05-22-2013, 02:02 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Hey we learned something. I'll second the "never say never". Thanks for passing on the fix ex.
