Go Back   Automotive Forums Car Chat > GMC > Acadia
Old 04-22-2013, 11:01 AM
fallin22 fallin22 is offline
Acadia transmission jerking
My 2009 Acadia has been jerking or skipping for a few months and is getting worse. We have took it to 2 different GMC dealers and they can't find a problem. It seems to happen after the car is drove for 30 minutes or longer and when you are going a steady speed 55-65 and then pull a hill or try to accelerate slowly. On the interstate this past weekend it was awful. It would do it 5-15 times in a row and the rpm hand would be bouncing up and down really fast about 2-3mm. Any suggestions from anyone or has anyone else had this problem? A friend of mine said it could be the spark plug or coils?
Old 04-22-2013, 06:38 PM
maxwedge maxwedge is offline
A990 racer
Re: Acadia transmission jerking
Welcome to AF, how many miles, big piece of info missing here. Does the check engine lite flash when this happens?
Old 04-22-2013, 09:35 PM
75k miles the check engine light flashed on and off about 10-12 times then went off and stayed off. Dealer called today said they think one of the coils is bad
Old 04-23-2013, 08:44 AM
A990 racer
Agreed, the flashing cel indicates a dead ignition misfire.
Old 08-16-2013, 08:34 AM
So I took my Acadia to the dealer and they replaced coil #6 back in April and everything was great until this week it started doing the same thing again. My question is should I go ahead and replace the remaining 5 or have them to just replace the one that is bad?
Old 08-16-2013, 11:28 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
fallin22,
I am sorry to hear you are having this concern. If you would like some assistance, I can assist you with looking into this concern. You can private message me your name, VIN, address, phone number, and name of your GM dealership. I look forward to hearing from you.
Erica Tiffany
GM Customer Care
Old 08-31-2013, 10:00 AM
It will not let me send a private message. The service manager at the dealer said this has been a recurrent problem and GM even may offer a recall. They quoted me $850.00 to replace the other 5 coils but I can purchase the coils for 22.00 each. Can anyone tell me if it's possible to replace them myself? Thanks for any help
Old 09-04-2013, 06:48 PM
Erica I recieved your private message and every time I try to reply it says error. Can you email me at [email protected] or give me a # to call you at.
Old 09-04-2013, 10:15 PM
Hello,
We're sorry that you've had troubles contacting us. We did post a response to your message. Please let us know if you've received it.
Amber N.
GM Customer Care
Old 06-19-2017, 09:47 AM
JTill JTill is offline
What was the diagnosed problem and solution to this issue? My 2011 is doing the EXACT same thing.
Please advise!
Thank you!!!
Old 06-19-2017, 06:52 PM
Blue Bowtie's Avatar
Registered Offender
What error code(s) is stored? That will provide a potentially useful clue.
Old 06-22-2017, 07:52 AM
No codes or check engine light...just continues to do the exact same; RPMs jump and fluctuate the longer I drive it at steady speeds of 55+
Old 06-30-2017, 07:12 PM
mbalsam mbalsam is offline
Thumbs down Re: Acadia transmission jerking
I own a 2012 Acadia Denali and am having the same problems with the jerking motion. Englewood GMC said it was the coils and they changed two of them. It's still having the same problem two weeks later. Truly thinking about selling the car and getting a Ford Explorer or Jeep Grand Cherokee. How could GMC not step up the plate with this. If it is the torque converter I'm looking at $2000 which it should be covered under the powertrain warranty.
Old 06-30-2017, 09:07 PM
We are replacing all 6 coils and plugs. I will keep you updated if that works. In the meantime, if anyone else has any solutions, please lmk!
Old 07-06-2017, 05:43 AM
JTill any luck?
Tags
acadia , transmission
