Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-07-2003, 03:00 PM
detoX's Avatar
detoX detoX is offline
another N2O ? for my 7th gen
ok ok heres what im am planning to setup my 7th gen..
100-150 shot of NOS
forged pistons
eagle rods
currently i have..
aem cold air intake
custom headers 421, 2.5 piping, mufllers
V-afc(no use I know..just wnted it )
...thats about it. my question is do you think it will hold up? anymore suggestion that i should get or parts that i should upgrade would be great! thanks!
Old 06-07-2003, 05:00 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
dont know much about nos but for sure you'll need a faster fuel pump and larger fuel injectors
Old 06-07-2003, 05:03 PM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Sounds good as far as bottom end prep goes. Now you need to work on the most important part of a nitrous setup. You FUEL SYSTEM.
Not familiar with your cars specs specifically, but you're probably going to want to upgrade your injectors, fuel pump, fuel rails, ignition and you're also going to want to look into some sort of tuning. Rather it be on a dyno or at home. To get the most out of a larger n2o shot you need tuning time.
There's no replacement for displacement...No, not even a turbo.
Old 06-07-2003, 06:44 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
if you're goona reinforce the bottom end why not just go turbo
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 06-07-2003, 10:42 PM
BullShifter's Avatar
Learn as much about nitrous oxide as you can before using it. There are many good books to provide proper information.
Old 06-08-2003, 11:24 AM
Cronic Cronic is offline
Send a message via AIM to Cronic
Engine managment would be a good idea after a 100 shot.
You will require larger injectors and a walbro 255lph pump. It's just intelligent. If you don't upgrade those, you will run lean, your motor will die.
Nothing left but a force fed hamster...
Old 06-08-2003, 02:55 PM
even better, why not go turbo & nitrous?
Old 06-08-2003, 03:26 PM
PWMAN's Avatar
PWMAN PWMAN is offline
Yeah baby! Turbo and juice is the shit!
Old 06-08-2003, 04:13 PM
I know this has nothing to do with this, but . . . .has anyone ever seen the land speed record semi's? The unlimited classes use twin superchargers & quad turbos with intercooler/aftercoolers.
Old 06-08-2003, 06:15 PM
Neutrino's Avatar
Yaya Master
for a dry shot even for a 30 shot you'll need engine management....fortunatelly most dry systems come with some form of piggyback that will force more fuel in....the stock ecu will never be enough(inless reflashed)
i agee
(\__/)
Old 06-09-2003, 06:13 PM
2001 civic n2o 2001 civic n2o is offline
Send a message via AIM to 2001 civic n2o
100-150 that's pushing it........i got a stock motor and squeezing 50 shot . wet system .......the most i could squeeze with the stock motor is 75 shot . but since you're reinforcing the internals . you should be ok. just do your research and think about the rest of the engine.............aloha!
Old 06-09-2003, 06:21 PM
just a reminder , you cannot squeeze a dry system on your 2001 civic.
Old 06-09-2003, 08:43 PM
PWMAN's Avatar
Why not?
Old 06-09-2003, 08:56 PM
Neutrino's Avatar
Yaya Master
Why not?
yeah why not
(\__/)
Old 06-09-2003, 11:06 PM
Originally posted by Neutrino
i agee
The 240cc injectors can safely compensate for a 55 DRY shot. No need for engine managment if your not going larger.
If your going any bigger please get a wet kit. as it will supply the fuel needed IF it can, meaning IF your pump and injectors can supply the needed fuel. So upgrade if your going bigger.
metra turbo kit bracket for 7th Gen bezzleman Galant 0 07-23-2005 09:42 PM
how much work for a b-series into a 7th gen civic? ricergribbs Engineering/ Technical 6 01-13-2004 07:31 PM
Looking for a TRD 7th gen celica wing sausage Car Modeling 4 08-03-2003 12:29 PM
looking for a 6th or 7th gen civic emblem slammed89civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 01-15-2003 04:34 PM
Lots of 7th gen. civic coupe pics for you... kicker1_solo '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 05-22-2002 07:02 AM
