Old 03-10-2013, 01:59 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
2002 Ford Escort ABS Codes
ABS light is on. Turn the car off, back on, light comes on when you begin driving and stays on.
Scanned got the following codes...
C1155 - Left Front Wheel Speed Sensor Input Circuit Failure
C1146 - Right Front Wheel Speed Sensor Input Circuit Failure
C1246 - Right Rear Outlet Valve Coil Circuit Failure
C1194 - Left Front Outlet Valve Coil Circuit Failure
C1198 - Left Front Inlet Valve Coil Circuit Failure
Cleared the codes and drove. Only one to return was C1194. I did have the front speed sensors disconnected for a time while checking the wires so that may have been the reason I got C1155 and C1246.
What can I do to diagnose without replacing the whole module. Car only has 40k miles. Vin P engine.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
