Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-09-2013, 03:51 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
94 Bird Coupe shiftng broke
Having trouble removing shift handle/knob.
Auto trans with floor shift.
Release button popped out. Broken.
Need to remove shift handle/knob for repair.
But can not figure out how.
Thanks for any help.
MT-2500
MT
Old 01-09-2013, 05:33 PM
DeltaP DeltaP is offline
Re: 94 Bird Coupe shiftng broke
Depress the detent button in, hold it and pull up sharply on the "tee" knob to detach it from the shifter. On later models theres a retaining clip that has to be removed,(with needle nosed pliers). Just under the "tee" at the back of the knob. If your button has popped out i guess you'll have to reach in and push the plunger. HTH
Old 01-09-2013, 06:54 PM
MT-2500's Avatar
AF - Advisor
Thanks for the info.
Problem is I can not find or see detent button.
IT has a leather cover over the tee handle/knob.
Is the detent button under the leather cover?
Thanks for the info on it
MT
Old 01-09-2013, 07:13 PM
Correction, your release button = my detent button.
Old 01-10-2013, 08:24 AM
MT-2500's Avatar
AF - Advisor
Is it under the leather cover?
MT
Old 01-11-2013, 01:05 AM
I'm referring to the park release button on the left side of the 't' handle... the same button that has broken on you. Press it in,(in your case it sounds like you'll have to push the plunger in), then pull up sharply on 't' handle to disengage the shift knob from the lever.
Old 01-11-2013, 08:22 AM
MT-2500's Avatar
AF - Advisor
Thanks
I have a new button on order.
Will give that as try hen button gets here.
MT-2500
MT
Old 01-11-2013, 05:39 PM
Lemme know how it turns out. Hope I helped someone today. Been one of them days.
Old 01-11-2013, 06:05 PM
MT-2500's Avatar
AF - Advisor
Ok
Ford said back order on it.
May be a few days.
I have them days to.
MT
