Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-08-2013, 02:09 PM
prashant833 prashant833 is offline
Post Car batter/battery/Alternator problem
Hi,
Recently I have faced a new issue with my car.
Sometimes and not always when I try to start my car, it does not.
The lights on the dash board appears initially but once the car does not
start they go off.
I then go and use my keys to hit the negative terminal of the battery. Once I do it for a couple of times(hit the terminal with key for about 10-15 times). All lights come up on and then I can start the car.
-- The terminal is not corroded.
-- The terminal does not look loose.
-- The battery has been checked and is GOOD
I am worried what else can be the problem? Please help..
Old 01-10-2013, 01:51 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Car batter/battery/Alternator problem
I would replace the ground cable and terminal, then the battery if the cable doesn't fix the problem. Intermittent connections are tough to determine.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Tags
alternator , battery , terminal
