Old 06-06-2003, 03:21 PM
dinplant dinplant is offline
Question 91 Accord All Door open lights are on
My 91 Handa Accord recently started leaving the door open indicator lights (5 in total) on all of the time.
Usually they go after after the car starts.
All my doors and trunk are closed tightly.
What does this mean?
Thanks in advance.
Old 06-06-2003, 06:24 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
if you open the door do they turn off? :hehe:
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 06-07-2003, 01:50 AM
knorsk knorsk is offline
man if that is the worst thing that has happened to your car...try just disconnect your batt. and wait ten minutes.
remember to keep it tucked between your legs (if ya wanna
pretend you are a woman)
You can find me at ImportRuiner.com
Old 06-07-2003, 12:20 PM
If I open the door they do not turn off.
All the lights turn off sometimes, this morning all is OK.
Other times they never turn off after starting the car.
Old 06-07-2003, 06:05 PM
try leaving the doors open when you disconnect the batt. for 10 minutes then reconnect it and close your doors. Maybe they are mixed up. Also you can check and see if you door sensors are even working they should probably be a springy button thingy on the inside crease of the door right were the hindges are. open the door and try pressing them and see if the light will go off or if it is just frozen/and or electical.
Old 06-07-2003, 06:06 PM
I think you could also try starting the car with one door open and see what the sensor indicates
Old 06-08-2003, 12:42 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
have you moved any wires lately? I know when I was putting in my fog lights and I was looking for a spot to mount my power relay, I mounted it on on of the grounds, thinking, ok, the grounds will have contact, because they are underneath and touching the body.. but to my suprise, when I started my car. the headlights only 1 worked, my wipers would turn on, and my elec. door locks would not work. so check all your grounds, and makes sure they are working properly, you might also want to check all your fuses..
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 06-09-2003, 12:36 PM
When all door sensor lights are off (normal) all of the door sensor work open and closed each door including the trunk and each lamp lights and extingushes. On / Off immediately (no fading).
When When all door sensor lights are on (bad) open and close doors has no effect to any lamps.
Also noticed this AM that when they finally went of this AM after driving a block or two the lights slowly faded out (strange!!!).
Door won't open StarSk8Grl13 6 1 04-19-2009 10:59 PM
1991 celica GT door open light srbernier Celica 1 03-30-2004 03:42 PM
Door open light always on. Which wire? springfire Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 03-27-2004 10:09 AM
