Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 12-15-2012, 11:42 AM
iceman_1227 iceman_1227 is offline
Cool 99 Chevy express cold air problme
Hello my chevy express does not have A/c but only the dial where you can turn from hot to cold and somewhat cold air will come out. Recently no matter what position the dial is in the air comes out extremly hot. Any ideas what the problem may be. I checked all fuse and the wiring in back of dial.
Thanks
Old 12-16-2012, 10:10 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 99 Chevy express cold air problme
Thanks
Tempture door not working.
Is tempture control changing votage to temp door actuator?
MT
Old 12-16-2012, 11:50 AM
Not sure, where is it located at and how do I check it?
Old 12-16-2012, 02:41 PM
DeltaP DeltaP is offline
Unless I read wrong this van doesn't have A/C as standard equipment? If that is the case you can check the heater control valve.
Old 12-16-2012, 05:02 PM
MT-2500's Avatar
AF - Advisor
G and express vans do not use heater control tempture vaves.
MT
Old 12-16-2012, 05:07 PM
MT-2500's Avatar
AF - Advisor
Located on HAVC pleum.
3 wires to it.
One brown wire 12 volt
Black is ground.
Light blue wire is grounded threw reister in tempt control switch to move motor hot to cold.
Check for 12 volts and ground and for reister ground threw tempt switch.
MT
