Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 10-16-2012, 11:38 AM
yamaha605 yamaha605 is offline
2000 avalon heated oxygen sensor
Check engine light came on plugged my obd2 in and got p1135 and p1155. according to manual its bank one sensor one and bank 2 sensor 2 heater circuits. bank one sensor is reading right but i cant read back to ground on my plug that i plug the o2 sensor into where does the ground wire go to please help.
Old 11-20-2012, 06:34 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2000 avalon heated oxygen sensor
My information is that DTC P1155 relates to Bank 2 Sensor 1, not Bank 2 Sensor 2. Please double check your information.
Ground wire for Bank 1 Sensor 1 and Bank 2 Sensor 1 heater circuits go to connector E5 pins 3 and 4 on the ECM.
I don't believe you have a Bank 2 Sensor 2 in your vehicle. Both sensors you have to check are in front of the cat convertor. Your Sensor 1 sensors are both A/F ratio sensors. The sensor behind the cat convertor is Bank 1 Sensor 2 and is an HO2 sensor.
With ignition on, check voltage to ground of terminals HAFL and HAFR on ECM. (Top middle pair in second connector from left) Should be 9-14 V.
Check resistance of A/F sensor heater
(a) Disconnect the A/F sensor connector.
(b) Using an ohmmeter measure the resistance between terminals +B and HT (two connectors furthest from the two ridge side of the connector).
Resistance:
At 20°C (68°F) 0.8 - 1.4 ohms
At 800°C (1,472°F) 1.8 - 3.2 ohms
If the resistance is not as specified, replace the sensor.
Torque: 44 N·m (450 kgf·cm, 32 ft·lbf)
(c) Reconnect the A/F sensor connector.
Check A/F sensor heater relay (Marking: A/F HTR in relay box next to battery).
1. REMOVE RELAY BOX COVER
2. REMOVE A/F SENSOR HEATER RELAY
3. INSPECT A/F SENSOR HEATER RELAY CONTINUITY
(a) Using an ohmmeter, check that there is continuity between terminals 1 and 2 (Two terminals parallel to long side of relay). If there is no continuity, replace the relay.
(b) Check that there is no continuity between terminals 3 and 5 (Two terminals parallel to short side of relay) when no voltage is applied across 1 and 2. If there is continuity, replace the relay.
4. INSPECT A/F SENSOR HEATER RELAY OPERATION
(a) Apply battery voltage across terminals 1 and 2.
(b) Using an ohmmeter, check that there is continuity between terminals 3 and 5 at this time.
I have a Toyota FSM if you need to download one.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
