Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-23-2012, 11:08 AM
DaChevyClassic DaChevyClassic is offline
New optispark and timing chain
I just put a new optispark and timing chain in a 94 Chevy caprice 4.3 engine. I crank the engine up and it idle good as hell, but while I'm driving it miss firing real bad. What can this be?
Old 09-23-2012, 11:59 AM
Tech II Tech II is offline
Re: New optispark and timing chain
What was happening prior to this?
It's possible it's a secondary misfire? Bad coil, wires, plugs? Fuel pressure/delivery?
New optispark distributor(complete?) or something used?
Old 09-23-2012, 12:28 PM
The car was running fine. I just wanted to give it a good tune up. It's a brand new optispark. I just don't know why it is misfiring.
Old 09-23-2012, 11:02 PM
Blue Bowtie's Avatar
Registered Offender
Were new wires part of the tune-up?
Did the timing chain go in with the marks aligned?
Old 09-24-2012, 04:51 PM
No new wires were added. And the timing chain was aligned right.
Old 10-02-2012, 02:28 PM
96capricemgr 96capricemgr is offline
Whole lots of fail here.
The opti is blindly cursed by stupid people who are the majority on the internet and it takes newb awhile to realise it is a good piece. If nothing was wrong and you just wanted to do a tuneup on any other distributor equipped car you would have just bought a cap and rotor right? What opti did you buy? Some of the aftermarket one range from worse than stock to horrible and some of those have "performance" brand names on them.
Why in the hell would you do a timing chain as a tuneup item????? You hang out with a bunch of ricers with timing belts on their cars? Timing chain is NOT a tuneup item, it is basically life of the engine, they even get reused with cam swaps and such without issue.
I would guess this is damaged or unseated/loose plug wires specifically from all this work you just did.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
Old 10-02-2012, 05:35 PM
j cAT j cAT is offline
come on now ! that is really being hard on this member.
I doubt he did this work. most likely a scam repair shop screwed him .
