Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-09-2012, 06:13 PM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
RamJet 350 no start
Does anyone know if the computer (MEFI4) turns the fuel injectors on without the control module? The motor cranks fine but the fuel injectors are not getting any electrical juice. Before I go spending 500 on a computer I want to check with you guys first. Thanks!
Old 09-09-2012, 09:37 PM
Tech II Tech II is offline
Re: RamJet 350 no start
What year? Usually all injectors are powered by a fuse, and each injector is grounded individually by an injector driver in the ECM/PCM.....
Old 09-14-2012, 11:11 AM
Well its an aftermarket engine.sold by chevrolet, I was wondering if perhaps the module wasnt supplying the signal to the computer, mayb I have a faulty module?
Old 09-14-2012, 02:48 PM
maxwedge maxwedge is offline
A990 racer
12v to the injectors but no ground side pulse? What year engine and injection system?
Old 09-16-2012, 07:34 AM
The Ram Jet Engine uses a MFEI 4 computer and has a Multiport fuel injection system, I checked all the grounds since there are only 3 or 4 and they were all good. I checked all the battery supplied 12 volt points and there's power everywhere. It cranks over well and if I put fuel down the throttle it will start up! I put a noid light to a few injectors as I was attempting to turn it on and nothing from the noid. This computer receives a Vehicle Speed signal from the module so I was wondering if perhaps the module could be at fault since my other option is the 500 dollar computer. I ordered a new Module P/N 10482830 so I guess I will change it out and will keep you guys up to date.
Old 09-16-2012, 08:56 AM
Blue Bowtie's Avatar
Registered Offender
Verify the control has the reference pulses from the distributor.
