Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-16-2012, 12:09 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Cooling fan failure
'04, 4 Liter with 128k miles.
Had the "it's fine on the highway but in town it starts to overheat". So after investigating, found that the original fan was only turning at slow speed; my model does not have the relay under the passenger headlight, but rather the 3-wire harness to the cooling fan, so I replaced it. Worked fine for a short while, but we are back to low (VERY low) speed only.
I'm leaning towards having the electrical system checked; at this mileage there could be a chafed wire causing the issue.
Any thoughts?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 07-16-2012, 06:12 AM
Jeff Collision Jeff Collision is offline
Re: Cooling fan failure
There are three wires going to the cooling fan, one is ground, one is power for the low speed fan and the other is power for high speed fan. You need to check power to both fan relays with the key on and engine running. Both should have powers. The computer grounds each relay to activate that specific circuit to power up the fan.
Old 07-20-2012, 02:33 AM
Thanks...hopefully it isn't a computer fault. If it is I'll consider a mechanical fan.
'85 Calais cooling fan relay location saxonmor Cutlass Series 0 07-07-2010 10:03 PM
help with a 92 spirit cooling fan backyardmec_an_ic General Discussion 1 10-30-2009 09:57 PM
cavalier 99 cooling fan drtyrocker Cavalier Problem Diagnosis 3 07-01-2009 09:08 PM
Vp holden engine fan failure iashco General Discussion 2 05-10-2004 10:17 PM
cooling fan failure Gail Crocenzi 3 Series 4 03-12-2002 09:28 PM
