Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-14-2012, 01:19 PM
jubil22 jubil22 is offline
Unhappy Vent, A/C, Defrost vacuum switch problem
I have a 1993 Mustang LX. I was working on the A/C fan, vent cluster and heard a little hissing noise. Now when I turn the A/C on it blows through the defrost and heat vents, it won't switch to the dash vents.
I assume I lost vacuum on the switch. Can anyone tell me how to fix this problem. I tried tightening the nuts on the vacuum hoses but no luck.
Thanks for any help.
P.S. It was working before I heard the hiss noise. I was working on the hot/cold switch at the time. The plastic clip that slides the wire is broken.
Would it be better to just replace the whole cluster?
Solution to A/C switching vents on its own under engine load. olopezm Windstar 15 05-11-2016 04:09 PM
2000 Windstar Air vents not working right olopezm Windstar 11 08-04-2010 09:09 PM
2001 monte carlo defrost vents problem catfishjr241 Monte Carlo 1 07-25-2010 03:16 PM
Vacuum switch problem Jlbloom40 Taurus | Taurus Wagon 1 07-07-2010 11:52 PM
Broken vacuum line from vacuum switch to vacuum ball 97BlazerDude Blazer 1 08-07-2005 02:53 PM
