Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 06-04-2003, 12:09 PM
Dima r33 Dima r33 is offline
Exhaust mods question
Hiya guys,
can you help?
My current mods to my 95 skyline gts25t are high flow panel air filter and 3.5 inch exhaust from the cat back.
I am thinking of connecting exhaust all the way up - getting a front 3 inch pipe and high flow cat - I know that this will give me more top end power via better breathing. But I was wondering what effect this would have on throttle response and low rpm down torque. Am I sacrificing low down torque for top end horsepower because of too little backpressure??? Will off boost driveability suffer? This is what i have been told. Is this true?
Help?!
Old 06-04-2003, 12:13 PM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
You would have been fine with a 3 inch system as they are good for about 550hp.
You may loose a slight bit in the under 3,000 rpm range but minimal.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 06-04-2003, 12:27 PM
thanx,
have heaps more questions 4 u all
-why does this happen tho? (the drop in low down torque)
-what kind of power and ultimate torque gains can i expect from fitting ---the front pipe and high flow cat?
(currently supposed to be 187kw - 250hp and 295nm)
-will peak power and torque be produced further up in the rev range?
-what kind of effect does this have on fuel economy?
-what other mods can i do to the car without playing around with the boost or the ecu?
Old 06-04-2003, 12:33 PM
Also,
If i rip up the isides of my existing cat wont this have the same effect as fitting a high flow cat and save me some cash?
Old 06-08-2003, 07:49 AM
BOOSTD's Avatar
BOOSTD BOOSTD is offline
Hi there. With a turbo back 3 inch exhaust you will be looking at about a 10kw gain (above standard) at the rear wheels. You will sacrifice a very small amount of low end power but trust me it is minimal and worth the mid to top end gain. As far as pulling out your cat is concerned I personally wouldn't do this but it is your choice. A high flow cat is not exactly expensive so my suggestion would be to put a good one in. If you want more power you could get an electronic boost controller and raise the boost a little but it is probably best to fit an intercooler before you start playing with boost levels as you will start to generate a lot of heat. Good Luck with it.
Niall.
Old 06-08-2003, 04:02 PM
RazorGTR's Avatar
Skyline Man
I had a 3 " high flow cat on my GTR when it came from Japan. I did a dyno with it on and then gutted it and redynoed it. It made no difference at all. So unless it is blocked you will gain nothing.
Old 06-09-2003, 03:21 AM
BOOSTD's Avatar
RazorGTR is right, adding a high flow cat won't really make any difference. Replacing the stock front pipe will though.
Old 06-09-2003, 04:18 AM
Cool. Does it at all matter that the front pipe and cat are 3' and catback is 3.5'. Does it need to be the same all the way thru?
Old 06-09-2003, 04:27 AM
BOOSTD's Avatar
Nah that doesnt really matter. If the catback system was a lot smaller than the front pipe then you would have restriction problems, but your setup will be fine.
Old 06-09-2003, 08:25 AM
BOOSTD whats the ultimate effect on fuel economy with this kind of mod?
Does it suffer coz the car has to be revved harder to go or does it improve somehow?
Old 06-09-2003, 08:45 AM
180driftking 180driftking is offline
Send a message via AIM to 180driftking
dope 180 pics, whered you get em?
Old 06-10-2003, 06:30 AM
BOOSTD's Avatar
Dima R33, fuel economy will suffer a little bit but you have to expect that when you are seeking more power. It won't get too bad until you start raising the boost and upgrading turbos etc.
180driftking, I get my pics from all over the web. I have posted a drift links thread in the Initial D forum. Here it is.
http://www.automotiveforums.com/vbulletin/t108221.html
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
mx6 exhaust mod causing engine running problems motomad MX-6 2 02-27-2004 01:15 PM
2001 Caravan Air Intake/Exhaust Mods? conncarl Caravan | Voyager 1 12-27-2003 10:18 AM
exhaust mods... compaq1207 Engineering/ Technical 2 08-10-2002 11:07 PM
*news flash* 10 dollar exhaust mod adds 20 horsepower!!!! JasonAccord98LX Engineering/ Technical 8 07-23-2002 02:16 AM
