Old 07-11-2012, 04:03 PM
Walis Walis is offline
2000 Ford Taurus - HEAVY JERKING
hello to all experts here.
I have a 2000 Ford Taurus SES that jerks heavily after being driven for about 5 mins. She starts right up, idles well, runs well in the beginning but then suddenly will start jerking when pressing on the accelerator. I'll pull to the side, put the car on neutral and rev the engine a little to see if any hesitation - NONE. Then once I put it in drive again and step on the gas, it feels like the tranny or something is jerking and about to fall off. If I park it and turn the car off for a while, then return to it, start it and drive it, it'll run fine for a few minutes and then the problem will start again.
Please help!!!
Old 07-11-2012, 04:11 PM
MyTaurus8AChevy's Avatar
MyTaurus8AChevy MyTaurus8AChevy is offline
Question Re: 2000 Ford Taurus - HEAVY JERKING
Have you checked tranny fluid levels?
Old 07-11-2012, 07:56 PM
danielsatur danielsatur is offline
Is the deliverability of horse power , but not transmission?
If loss of HP with no DTC's, it could be as simple as a plugged catalytic converter.
If no, it's time for a new transmission fluid/ filter change.
Old 07-11-2012, 08:39 PM
tempfixit tempfixit is offline
Originally Posted by danielsatur View Post
Is the deliverability of horse power there, but not transmission?
If no, tt's time for a new fluid/ filter change.
To me it sounds like a fuel pump problem. When the car will not run squirt somme throttle body cleaner in the throttle body and see if it will run on it, if so a fuel delivery issue.
Get a cheap fuel pressure testing gauge (harbor frieght) and watch the fuel pressure when driving.
Old 07-11-2012, 08:52 PM
If loss of HP, it could make a good transmission look bad.
Random misfires on random cylinders -
Air - Bad or dirty air cleaner, MAF sensor, H20 sensor, unmetered air leaks on PCV, EGR, and air Intake systems.
Fuel - bad fuel filter, fuel pressure, fuel pump, fuel regulator
Ignition - Bad crank, or cam sensors.
Exhaust - Plugged cat or catalytic converters.
Old 07-11-2012, 11:15 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Welcome to the forum!
When's the last time the car's had a tune up? Your symptoms, as described in the original post, sound like a misfire due to worn plugs, bad spark plug wires, or possibly a vacuum leak.
-Rod
Old 07-12-2012, 06:52 AM
air filter is new, spark plugs are new, coil packs are good. If fuel delivery issue, I'd assume the problem will be constant whether the car is in park, neutral or in drive...correct? The problem, once it starts, is only when in drive and the accelerator is depressed. I've put the in neutral to see if there was any hesitation but NONE. Once i put the car in drive and try to drive, it jerks heavily. A key point here is that the problem begins after about 5 minutes of driving.
Car runs fine for the first 5 mins.
Car begins to jerk heavily after 5 mins of driving only while in drive and accelerator depressed.
Car put in neutral or park after problem starts does not show any hesitation.
Car put in drive and problem continues.
Thank you ALL. Please HELP!!
Old 07-12-2012, 07:38 AM
shorod's Avatar
SHO No Mo
Were these items all changed in an attempt to fix this issue, or installed shortly before the issue started? Do you have access to a scan tool with datastream mode?
-Rod
Old 07-12-2012, 12:01 PM
It's really hard to tell the deliverability of the engine hp just by putting the car transmission in Neutral or parked position.
We want to see the hp @ the rear wheels, let's put a load on her by going up hill + pedal to the metal, hopefully this will be enough to throw a code.
Old 07-29-2012, 07:01 PM
thanks to all of you for the helpful tips. I've now derived at my brakes locking up as the culprit of my problem...I think? The rear brakes lock up intermittently...now the front brakes lockup after some minutes of driving. I've changed the two front brake calipers, the rear brake cylinders and still no avail. I noticed the front brakes unlock after letting the car rest for a couple of hours.
What could be making my brakes lockup? HELP PLEASE!!
Old 07-29-2012, 09:16 PM
shorod's Avatar
SHO No Mo
I really doubt that brakes are reason for the symptoms you describe in the original post, but I suspect that there's a reason you are leaning that direction. Please share what you've recently discovered that caused you to look towards the brakes.
For what it's worth, if it were an intermittent brake lock up, I'd be looking more towards the rubber brake hoses than the calipers and wheel cylinders, but again, I really doubt brakes are causing the "heavy jerking".
-Rod
Old 07-30-2012, 07:29 AM
thanks Shorod. let's take out "intermittent" on this. I've tried repeatedly and found the front brakes to be locked up every time the problem begins. Once the problem begins, I quickly park the car, jack it up, and the the gear on neutral. I tried spinning each front wheel but both will not spin not even a mere turn. So the last time I tried, I left the car on the jack and switched the off. When i returned to the car after a couple of hours, the wheels spun easily and freely.
What could be the issue here?
thank you.
Old 07-30-2012, 08:00 AM
shorod's Avatar
SHO No Mo
So I would assume then every time this happens it's after you've use the brakes a few times. Something is keeping the calipers and wheel cylinders from retracting. Since the calipers and wheel cylinders are new, about the only thing that could cause this would be rubber brake hoses that have collapsed and are now acting a bit like one-way valves, allowing fluid to be forced to the calipers/cylinders, but do not allow the fluid to freely flow back to the master cylinder (which is under much less pressure). I'd certainly suggest you carefully inspect the brakes first though to make sure the pads are wearing evenly and were installed correctly as well as checking the rear to confirm the shoes were installed correctly. Several drum brake setups use one shoe with "short" friction material and one with "long" friction material. Make sure both "long" shoes didn't get put on one side.
-Rod
Old 07-30-2012, 12:20 PM
you're correct Shorod. It begins to lockup gradually as I could feel it as the brakes begin to not release after multiple braking series. I drove to about 20/mph and let my foot off the gas pedal and the car literally came to a full stop as though I was the one braking. After which i began smelling the brake pads.
thank you very much.
Old 08-03-2012, 11:51 PM
plymouthsrock plymouthsrock is offline
Disconnect the vacuum hose to the brake booster and see if the problem occurs- don't forget to step hard on the pedal with no assist.
2000 Ford taurus jerking above 65mph taylor021 Taurus | Taurus Wagon 7 08-17-2010 01:12 AM
2000 Ford Windstar, Not a whole lot of knowledge cshawn Windstar 8 08-14-2010 06:40 PM
will the transmission in a 95 taurus work in a 2000 ford taurus bj_the_king Taurus | Taurus Wagon 1 11-10-2006 08:49 PM
2000 ford Taurus Keyless Entry MikePercak Taurus | Taurus Wagon 4 06-19-2004 11:35 AM
2000 Ford Taurus SE SVG-Engine Block Heater SlimD Taurus | Taurus Wagon 0 12-07-2003 08:48 PM
